EDIT: I want to clarify what is my intention in here, What I want to do is use one raspberry pi GPIO (which provides 0v or 3.3v whether it's up or down) to turn on or off an LED strip that requires 5v signals on the input (of course the strip is powered externally). I've seen this could be done easily with this transistor and 2 10k resistors but I don't know how to connect it because I don't know how to read that schematic. This arduino scenario was just to test if I could make this schematic work with the 3.3v rail and generate 5v.
I have just a little knowledge of electric circuits and I've been searching everywhere a guide on how to connect my 2N70000 transistor in order to get that 3.3v shift to 5v.
I've seen almost everywhere this picture but I have literrally no idea on how to achieve it:
This is what I came up with but I'm not sure, and I dont want to try it because I don't want to fry my arduino or the transistor:
EDIT2: final question. I want to know if this is correct, and also where do I need to connect GND pin of my RPi, this time I'm not doing it bidirectionally just one way because there's no need of feedback from the LED to the GPIO
  • \$\begingroup\$ I think I need to connect gate to ground, am I correct? \$\endgroup\$
    – Fjallbacka
    Commented Mar 21, 2017 at 0:09
  • \$\begingroup\$ If you want to replicate the schematic, you need to connect the gate to +3.3 V. \$\endgroup\$
    – The Photon
    Commented Mar 21, 2017 at 0:22
  • \$\begingroup\$ Yes I do want that. And the other is the same as I did or is it wrong? \$\endgroup\$
    – Fjallbacka
    Commented Mar 21, 2017 at 0:25
  • \$\begingroup\$ Connecting to ground is not the same as connecting to +3.3 V. As for which you did, I'm not going to try to decipher your breadboard. You check---is the FET gate connected to ground or to +3.3 V? \$\endgroup\$
    – The Photon
    Commented Mar 21, 2017 at 0:46
  • \$\begingroup\$ One thing that's not shown in your schematic, the device driving the low-side I/O, the device driving the high-side I/O, the +3.3 V supply, and the +5 V supply all need to be connected to the same ground net. One thing I don't see in your breadboard is anything providing power to the "+" rail of the breadboard. \$\endgroup\$
    – The Photon
    Commented Mar 21, 2017 at 0:49
Your circuit does not generate 5 V. You need to provide a 5 V power supply.
where do I connect the 3.3v signal, where do I connect the 10k ohm resistor, where is ground connected and where is 5v signal output?
The 3.3 V signal (from your RPi or Arudino) connects to the wire labelled "low side". The 5 V signal is output on the wire labelled "high side".
You also need to provide a 3.3 V power supply connected to the wire labelled "+3 V" and a 5 V power supply connected to the wire labelled "+5 V".
There are two 10 kohm resistors. One connects from the +3.3 V supply to the source pin of the FET. The other connects from the +5 V supply to the drain pin of the FET. This much at least should be obvious from reading the schematic.
I DO NOT KNOW HOW TO READ THAT SCHEMATIC, is not a simple one
This schematic is about as simple as they come.
The main gotcha is that ground is not shown, but must be present, and must be connected to the 3.3 V source, the 5 V source, whatever's connected the the low side signal line (your arduino), and whatever's connected to the high side signal line (your LED driver).
A more complete version looks like this:
The circuit you are using is for bidirectional signaling but you don't need that.
A much simpler (inverting) level converter would be something like this:
Again, you have to provide a 5 V supply, connected to the "+V" node. And choose resistor values that won't blow up your RPi or the transistor. If the input to the LED strip is a logic input, you could probably use ~2 kohms for both R1 and R2 and be fine.
Edit
No this is not correct. It is nothing like correct.
  1. The output is connected directly to a 5 V source, therefore it is always at 5 V or logical high, and it will never go low. Thus no signal from the input will change the value at the output.
  2. With the FET source at +3 V and a 3 V logic signal on the gate, the FET will never have a positive Vgs, so it will always be in the cut-off state. The input will never cause the FET to change state so the FET will not do anything useful.
  3. 10 kohms between +3 V an the GPIO output does nothing, since you are using (presumably) push-pull outputs rather than open drain.
You connect it to the ground of the 3.3 V supply that provides it with power, and you connect that ground to the ground of the 5 V supply that provides the destination circuit with power.
This is true whether you're using the original bidirectional translator circuit or the single-direction one I've suggested.
  • \$\begingroup\$ I've edited the main thread with a picture of what my circuit would look like, I don't know where do I need to connect GND in order to close the circuit. Could you please help me on that? I think I got it right this time. Thanks \$\endgroup\$
    – Fjallbacka
    Commented Mar 21, 2017 at 10:31
  • \$\begingroup\$ Ground goes to ground. How can a circuit tell whether an input is 0V, 3V or 3,000V if there is no agreed upon 0V to measure from? \$\endgroup\$
    – Andrew
    Commented Mar 21, 2017 at 12:49
  • \$\begingroup\$ @Fjallbacka, my "more complete circuit" shows how ground needs to be connected to make the bidirectional translator circuit work. All the power supplies and circuits involved need to have their grounds connected together. \$\endgroup\$
    – The Photon
    Commented Mar 21, 2017 at 15:50
