I have a small SOT-23 (3 pins, transistor-like) device that burned out (shorted between 2 pins). I need to identify it so i can replace it, but i can't find the code at all. The code is: SE and a simbol like a horizontal "P". Like this image:
Here's a picture of the device, although i don't think it will help much:
I'm not sure if it's a transistor, FET or diode.. It belongs (apparently) to a driver circuit for a P-Channel Power Mosfet, but that's all i can share because the circuit is almost impossible to follow.
Looked the code up on many webpages and can't find anything but a "2SC4703" RF transistor, but it's definetly not one suited for the actual circuit.
Any help would be apreciated.
