library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity TestRun01 is
    Port ( Clk : in  STD_LOGIC;
           Din : in  STD_LOGIC;
           Dout : out  STD_LOGIC_vector(11 downto 0));
end TestRun01;
architecture Behavioral of TestRun01 is
signal regr : std_logic_vector(11 downto 0) :="000000000010";
signal reg  : std_logic;
begin
    process(Clk,reg)
    begin
        if falling_edge(CLK) then
            if Din ='1' then
                reg <='1';
            elsif  Din='0' then
                reg <='0';
            else
                reg <= reg;
            end if;
regr<=regr(10 downto 0) & '0';
regr(0)<=reg;
        end if;
    end process;
    Dout<=regr;
end Behavioral;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY Test1 IS
END Test1;
ARCHITECTURE behavior OF Test1 IS
    COMPONENT TestRun01
    PORT(
         Clk : IN  std_logic;
         Din : IN  std_logic;
         Dout : OUT  std_logic_vector(11 downto 0)
    END COMPONENT;
   signal Clk : std_logic := '0';
   signal Din : std_logic := '0';
   signal Dout : std_logic_vector(11 downto 0);
   -- Clock period definitions
   constant Clk_period : time := 10 ns;
BEGIN
    -- Instantiate the Unit Under Test (UUT)
   uut: TestRun01 PORT MAP (
          Clk => Clk,
          Din => Din,
          Dout => Dout
   -- Clock process definitions
   Clk_process :process
   begin
        Clk <= '0';
        wait for Clk_period/2;
        Clk <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
   begin
--      wait for 1 ns;
        Din <= '1';
        Din <= '0';
        Din <= '0';
        Din <= '1';
   end process;
END;
Why there's a U?
And how can I get rid of it?
'U' means uninitialized. You have to give an initial value for reg signal like for regr in line signal reg : std_logic := '0'; or signal reg : std_logic := '1'; depends on your intention
