(Please see this question for background info)
In my pantry, I'm going to be connecting a door jamb switch across a low voltage application. I'd like to (instead of fishing the bare wire through a hole the wall) use a wall-plate with two connectors. I see that banana plugs can support 30v at 15a (way more than I would need), and come in a keystone jack. I am wondering though if using connectors typically for audio would present a hazard and if there is a better option that would be available in a keystone jack or standard wallplate.
  • \$\begingroup\$ Is the 'low voltage' AC or DC? Banana plugs are NOT POLARIZED, can be wired backward on a DC system. \$\endgroup\$ – Whit3rd Mar 23 '17 at 9:47
You could use banana's but they are notoriously unreliable for falling out when you don't want them too.
Phono-Plugs make a MUCH more reliable mechanical connection.
Or go with a coaxial cable.
As for labels, get some printable labels.
| improve this answer | |
