I am currently working on one of the BLDC drive applications.Due to higher current requirements it is planned to use multiple MOSFETs in parallel to distribute the current among themselves.
Here I wanted to know whether the gate-drive current from the driver I am using is sufficient or not. Could somebody give hints or procedure to make sure the driver you have chosen is right one? (You may consider example values as Vdriver(max)=12V, Vdriver(min)=0V, I_driver(max)=2A, MOSFET gate charge=150nC, No. of MOSFETs in parallel=3, Switching frequency = 16kHz.
I hope these are the basic parameters to do the analysis. Assume if you need anything else.
