I have multiple temperature sensor connected to microcontroller PIC16F887. How can I assign single PIN to a variable? Is it possible?
unsigned char  Check, T_byte1, T_byte2, RH_byte1, RH_byte2, Ch1;
unsigned Temp, RH, Sum;
unsigned int Temperature, Humidity;
unsigned char TH;
void SelectSensor(int sensor){
    if(sensor == 1)
        TH = RA0;
    else if(sensor == 2)
        TH = RA1;
    else
        TH = RA2;
void StartSignal()
    TH = 0;
    __delay_ms(18);
    TH = 1;
   __delay_us(30);
void CheckResponse()
    Check = 0;
    __delay_us(40);
    if (TH == 0)
        __delay_us(80);//80
        if (TH == 1){
            Check = 1;
        __delay_us(40);
char ReadData(){
     char i=0, j;
     for(j = 0; j < 8; j++){
         while(!TH );               //Wait until TH1 goes HIGH
         __delay_us(30);
         if(TH == 0)
             i&= ~(1<<(7 - j));     //Clear bit (7-b)
         else {
            i|= (1 << (7 - j));     //Set bit (7-b)
            while(TH1);             //Wait until TH1 goes LOW
    return i;
void calculateSignal(){
    StartSignal();
    CheckResponse();
    if(Check == 1){
        RH_byte1 = ReadData();
        RH_byte2 = ReadData();
        T_byte1 = ReadData();
        T_byte2 = ReadData();
        Sum = ReadData();
        if(Sum == ((RH_byte1+RH_byte2+T_byte1+T_byte2) & 0XFF)){
            Temp = T_byte1;
            Temp = (Temp << 8) | T_byte2;
            RH = RH_byte1;
            RH = (RH << 8) | RH_byte2;
            if (Temp > 0X8000){
                Temp = Temp & 0X7FFF;
            Temperature = Temp;
            Humidity = RH;
        else{
            //lcd_clear();
            //printf("ceksum error");
    else {
        //printf("no response");;
int getTemp(){
    return Temperature;
int getHumid(){
    return Humidity;
  • \$\begingroup\$ Why are you trying to do that? You should be setting the ADC mux. \$\endgroup\$
    – Matt Young
    Mar 24, 2017 at 1:15
  • \$\begingroup\$ So that i can reuse TH for different PIN. \$\endgroup\$
    – Tuss
    Mar 24, 2017 at 1:17
  • \$\begingroup\$ I can't make sense of what you're trying to accomplish. What is TH? What is it for? \$\endgroup\$
    – Matt Young
    Mar 24, 2017 at 1:19
  • \$\begingroup\$ How do you expect the micro to know which sensor it's reading from? \$\endgroup\$
    – DerStrom8
    Mar 24, 2017 at 1:20
  • \$\begingroup\$ All sensors(DHT22) are same. By selecting sensor 1,2 or 3, I can reuse same code to get temperature and humidity. I am expecting micro knows which sensor by referencing to different pin in PORTA. \$\endgroup\$
    – Tuss
    Mar 24, 2017 at 1:30
