I am making a circuit that uses the H11AA1 (http://www.vishay.com/docs/83608/h11aa1.pdf). This is a bidirectional opto-isolator. enter image description here
I want to simulate it in Proteus, but in the libraries there are only uni-directional opto-isolators. ¿How can I simulate this device, or something similar?
I am suppose to have something like this: enter image description here
Thanks in advance
    \$\begingroup\$ same as adding a diode bridge to input. ( except for added diode drop) \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Mar 24 '17 at 20:26
    \$\begingroup\$ Simply use two single LED opto-isolators with the output CE's in parallel and the input LED connection reversed. \$\endgroup\$ – Jack Creasey Mar 24 '17 at 21:13
how about rectifying that signal and then use a unirectional opto-isolator enter image description here
| improve this answer | |
  • \$\begingroup\$ I guess I have no other choice if I can't find how to simulate it. But since the voltage has a value of 120rms I think my final circuit is going to be a little bit more expensive and I haven't investigated how easily is going to be rectifying it \$\endgroup\$ – DieDauphin Apr 10 '17 at 23:03
