-1
  • \$\begingroup\$ Add a source to your circuit and click where it says "simulate this circuit". \$\endgroup\$
    – The Photon
    Mar 26, 2017 at 0:27
While there is not a compact analytic solution, some insight may derived from an open circuit time constant analysis.
In this method, we first compute the time constant associated with each capacitance:
$$ \tau_1 = 68 ~\text{pF} \cdot 0 = 0~s\\ \tau_2 = 2.2 ~\mu\text{F} \cdot \left(500\Omega || \left(5\text{k}\Omega+10\text{k}\Omega\right)\right) \approx 1.06~\text{ms} \\ \tau_3 = 100 ~\mu\text{F} \cdot \left(\left(500\Omega+5\text{k}\Omega\right)||10\text{k}\Omega\right) = 0.355~\text{s} $$
The overall time constant is the sum of these values:
$$ \tau_{OCT} = \tau_1+\tau_2+\tau_3 = 0.356~\text{s} $$
The predicted -3dB frequency is therefore:
$$ f_{OCT} = \frac{1}{2\pi\tau_{OCT}} = 0.447~\text{Hz} $$
This is within 0.2% of the value simulated in CircuitLab (0.446 Hz). Note that -3dB frequency is almost entirely set by the time constant of C3. In other words, there is a dominant pole.
  • \$\begingroup\$ I think you just gave him the answer to a homework question. It probably would have been better to provide an explanation and formulas, but left actual numbers out of it \$\endgroup\$
    – DerStrom8
    Mar 26, 2017 at 1:46
