I'm tying to use a atmega2560 but can't get the I2C working. When I send the address byte i get never a ack response. Does anyone see what i'm doing wrong i used the code out of the datasheet? I tried it with a logic analyzer and it works so I do know the IC isn't defect.
void i2csend(uint8_t addr, uint8_t reg, uint8_t data){
   TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
   while(!(TWCR & (1<<TWINT)));
   if ((TWSR & 0xF8) != 0x08)//A  START  condition  has  been transmitted
    stopi2c();
    return;
   TWDR = addr;
   TWCR = (1<<TWINT) | (1<<TWEN);
   if ((TWSR & 0xF8) != 0x18)//SLA+W has been transmitted;
                               ACK has been received
    stopi2c();
    return;
   TWDR = reg;
   while (!(TWCR & (1<<TWINT)));
   if ((TWSR & 0xF8) != 0x28)//Data  byte  has  been  transmitted;
    stopi2c();
    return;
   TWDR = data;
    stopi2c();
    return;
   stopi2c();
   return;
    \$\begingroup\$ A possibly good test to make is to sweep all i2c addresses and see if you get any acks. \$\endgroup\$
    – Wesley Lee
    Mar 25, 2017 at 23:31
A common problem when using I2C is to forget about shifting the slave address one bit to the left before using it.
An I2C address is just 7-bits left justified with the R/W bit at the bottom.
You don't say what the slave device is? Are you sure the slave address is correct.
I haven't written i2c code for the atmega2560 but I have for other AVR family members. The last one I did for an atmega328 I used the library from Fleury I2C library.
I found it useful to write an I2C scanner that would attempt to read from all i2c addresses and print out the ones where it received an ACK.
  • \$\begingroup\$ i'm using a pca9685 and here is the image from the datasheet i have connected the others to ground. so that is 0x40. [1]: i.sstatic.net/PJNyD.png \$\endgroup\$
    – Dylan
    Mar 26, 2017 at 0:33
  • \$\begingroup\$ Your code doesn't say what is the value of "addr"? I agree the SLA of your device is 0x40. variable "addr" should be 0x80 when you left shift and or in the W bit. (0x81 for a read) \$\endgroup\$ Mar 26, 2017 at 0:47
  • \$\begingroup\$ oh dam forgot about that \$\endgroup\$
    – Dylan
    Mar 26, 2017 at 1:08
