This question already has an answer here:
I am having some trouble wrapping my head around this, and it might just be some small error somewhere, that I keep missing .. but as it stands, I am trying to create a hardware "delay" that can run at the same time some code executes.
For practise purposes, I am simply trying to blink an LED at PD4 at an interval of 1 second.
I have used the following formula to determine the prescaler, and the value of the Output Compare Register A (OCR1A):
Formula for calculation
Using a prescaler of 256, I get a value for OCR1A of 62499:
Result of calculation
Looking at the registers TCCR1A and TCCR1B in the datasheet, I set the Waveform Generation Mode bits (WGM) to use CTC and the Clock Select bits to use the 256 prescaler.
Now, in my main function, I am starting of by turning on the LED, then calling my function that should start the timer. I am then checking to see if the overflow flag has been set in TIFR1, and if it has, I am turning of the LED and writing a logic 1 to TOV1 to reset the overflow flag.
int main(void) {
   DDRD = 0xFF;
   PORTD = 0x00;
   while (1) {
      // Turn on LED at PD4
      PORTD |= (1 << PD4);
      oneSecondDelay();
      // Checking to see if the overflow flag has been set
      if (TOV1 == 1) {
         // Turn off LED at PD4
         PORTD &= ~(1 << PD4);
         // Set 1 in the Output Compare A Flag to reset the overflow flag
         TIFR1 = (1 << TOV1);
   return 0;
In my function I start off by setting OCR1A to the value that I calculated earlier. I then set the bits in the TCCR1B register that needs to be set for using the specific prescaler and CTC mode, and I then create a loop while waiting for the overflow event to happen; which I envision should take one second.
void oneSecondDelay() {
   // Set the target value to 62499
   OCR1A = 0xF423;
   // Set prescaler to 256 and start the timer
   TCCR1B |= (1 << WGM12) | (1 << CS12);
   // Waiting for the overflow event
   while ((TIFR1 & (1 <<  OCF1A))) {
TLDR: Now the problem is that no matter what I can dream up, the LED is just constantly turned on, and I am not sure if I am setting the the wrong values in the registers, or if I am just having some brain farts?
marked as duplicate by Bence Kaulics, ThreePhaseEel, Community Mar 27 '17 at 19:49
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    \$\begingroup\$ You turn OFF the led after one second but then widout any "delay" you turn ON the led again. \$\endgroup\$ – G36 Mar 26 '17 at 10:07
  • \$\begingroup\$ Check this: 12 hours delay with ATmega16A. \$\endgroup\$ – Bence Kaulics Mar 26 '17 at 10:26
    \$\begingroup\$ Thank you so much @BenceKaulics ! Using the interrupt what something that I hadn't found, so this was a huge help and I finally thing that I understand it :) \$\endgroup\$ – Michael Nissen Mar 26 '17 at 11:31
  • \$\begingroup\$ G36 already gave a hint and I suggest you use an ISR for timer1 (ISR(TIMER1_COMPA_vect)) where you toggle your LED with PORTD ^= 1 << PD4; \$\endgroup\$ – Andy Mar 26 '17 at 11:32
    \$\begingroup\$ I tried doing what G36 talked about, but that didn't do it for me, however using the ISR did the trick.. I simply didn't know about the ISR before @BenceKaulics mentioned it ! :) But thank you for the answer! \$\endgroup\$ – Michael Nissen Mar 26 '17 at 11:34
that function's construct isn't terribly optimal. you could have easily made it take a parameter to determine the length of the delay, not to mention other issues.
A quick fix would be something like this - it still has issues but at least workable.
//create a user-specified delay
//dly-duration in timer ticks
//timer1 presummed running, running at 256:1 prescaler
void myDelay(uint16_t dly) {
   OCR1A = TCNT1 + dly - 1;     //0xF423;
   //TCCR1B |= (1 << WGM12) | (1 << CS12);
   TCCR1B = (TCCR1B &~0x07) | (TMR1_PS256x & 0x07); //set timer1 prescaler to 256:1
   while ((TIFR1 & (1 <<  OCF1A)) == 0) {
   TIFR1 |= (1<<OCF1A);         //clear the flag
that piece of code in action when fed TMR1_PS100ms as a parameter:
the goal of writing any piece of code is so that you don't have to write it again. That way, anything you write is an investment, not an expense.
  • \$\begingroup\$ Thanks for the answer! I know that I should use a parameter to specify the length of the duration, but I was just trying to wrap my head around how the whole AVR thing works, so trying to keep it at bare minimum. I managed to solve by using interrupts in the end :) Also, was wondering how you made that nice looking digital analysis at the end? :) \$\endgroup\$ – Michael Nissen Mar 26 '17 at 19:39
