8
Often a chip will be available in several different packages. Sometimes QFN which has a thermal pad, and TQFP which has no thermal pad. The justification for the thermal pad is that it helps conduct heat away from the IC. If this were the case, then why doesn't the TQFP need the thermal pad?
The reason I'm moaning is that the thermal pad gets right in the way of the layout. Tracks and vias can't be placed under the device (except in some cases), making fanout tricky in space confined PCBs.
Is the thermal pad just traditional, or is there a good reason I'm not aware of?
The answer is that "it depends". Also, I would like to point out that there are TQFP's with thermal pads, so this isn't a QFN vs TQFP issue. It's a Pad or No Pad issue.
Pro's:
  1. It's easier to cool a chip with a thermal pad. Some parts absolutely need this, while other parts can have an extended ambient temperature range with a pad.
  2. Some parts don't need cooling, but use the "thermal" pad as a very low impedance connection to GND. This allows for lower noise and EMI.
  3. QFN's have a lower lead inductance and are generally smaller than the equivalent pinned TQFP. This improves signal integrity and lowers EMI.
Con's:
  1. Makes hand soldering much harder. Not as bad as a BGA, but you'll certainly need a hot-air solder station and possibly a preheat device for the larger parts.
  2. Makes PCB routing more difficult, especially on 2 layer PCB's.
I personally would always choose a thermal pad over no pad, and always a QFN over TQFP. Of course most of my PCB's are 6 or 8 layer boards with 4 mil traces, so routing and fanout usually aren't a huge problem. Cooling is usually a problem for me. I do benefit from the smaller QFN's. And the better signal integrity and lower EMI is a huge plus for me.
The other side benefit is that nobody asks me to rework a QFN! :)
  • \$\begingroup\$ David, why a QFN over TQFP? Are there any particular advantages (besides cooling)? \$\endgroup\$
    – Saad
    Apr 8 '12 at 15:38
    \$\begingroup\$ @Saad Physically smaller and lower lead inductance (for better signal integrity and lower EMI). \$\endgroup\$
    – user3624
    Apr 8 '12 at 16:20
    \$\begingroup\$ Is the difference in lead inductance (nH?, pH?) all that important? After all, the pins connect to a PCB trace tens or hundreds times longer. \$\endgroup\$ Apr 8 '12 at 16:40
  • \$\begingroup\$ @FedericoRusso It really depends on your application. Obviously a slow signal won't care so much. High speed signals will care a lot. The lead inductance also effects more than just signals, it effects power and ground too and thus impacts ground bounce and other on-chip noise issues. When it comes to EMI testing, anything that helps is worth it! \$\endgroup\$
    – user3624
    Apr 8 '12 at 17:01
    \$\begingroup\$ @Rocketmagnet I'm not completely sure, but if I had to speculate I'd say that it's because the pins on a QFN are usually tiny and might not hold the chip on the PCB securely. \$\endgroup\$
    – user3624
    Apr 8 '12 at 17:49
David already said that there are also QFPs with thermal pads, like this PQFP-208:
On some devices it helps cooling the device, though you'll have to take additional actions. You'll need a lot of filled vias to transfer the heat to an inner ground plane. Also, most manufacturers recommend not to use a full central pad, since too much solder may lift the IC so that pins at the edge may not make contact with the solder paste.
Instead a patterned stencil is suggested, like this:
or
Note that this is just for the stencil, not the pad.
On low-power ICs which don't need the cooling I sometimes think that the thermal pad is just there to annoy us. In most cases you'll have to connect the pad to ground.
