I have designed a GSM/GPS based tracker which is installed at my bike. But it is draining battery too quickly.
So, I want to add a cutoff circuit when the bike is not running(battery not charging) for a long time and in addition, the cutoff circuit should reconnect power to load (my tracker) whenever the battery voltage rises to a preset leve (For say 12.6v).
I decided to use an op amp comparator based cutoff circuit. But the problem is I am unable to calculate hysteresis when the supply voltage of the op amp is changing (Because I will power the op amp from the battery itself).
Can I use a comparator hysteresis circuit if I have a variable voltage rail? If not what kind of changes to the circuit would I need to make this functional? enter image description here
  • \$\begingroup\$ You may want to crop that image and re-post it, posts are forever and we want them to look good for future reference. \$\endgroup\$
    – Voltage Spike
    Mar 27, 2017 at 6:30
If you want LOW POWER, at limited Temperature Excursion, try this:
By the way, this schem is edited (added output Zener/diode clamp) to provide more stable Vhysteresis.
  • \$\begingroup\$ How to calculate the value of R5 when the supply voltage of te op-amp itself is changing??That is my concern!! \$\endgroup\$
    – S.Das
    Mar 27, 2017 at 5:56
  • \$\begingroup\$ I am attaching a circuit that i designed so far.. \$\endgroup\$
    – S.Das
    Mar 27, 2017 at 5:59
  • \$\begingroup\$ @S.Das downvote answers that don't answer the question \$\endgroup\$
    – Voltage Spike
    Mar 27, 2017 at 6:29
  • \$\begingroup\$ @s.das You did not ask for constant hysteresis. Nor does the circuit you attached accomplish constant hysteresis. \$\endgroup\$ Mar 27, 2017 at 14:20
  • \$\begingroup\$ Consider added an output clamp, to achieve more stable hysteresis. \$\endgroup\$ Mar 27, 2017 at 15:17
