I have quite precise ADC circuit. I want to protect input supply voltage (not ADC input) from reverse-polarity using FET transistor as shown on the picture below.
I wonder: is there any noise / worse performance introduced in ADC measurements due to use of FET on the power line? Power supply is also reference voltage for ADC. The alternative for me is just not use any re-pol. protection.
  • \$\begingroup\$ This is impossible to answer without knowing anything about your ADC circuit. Maybe the ADC is very insensitive to supply noise. Maybe the supply decoupling will filter out the noise. \$\endgroup\$ Commented Mar 27, 2017 at 10:38
  • \$\begingroup\$ I'm afraid you haven't shown us the very part of the circuit you're asking about. Please can you modify the question to show this, the more the better (up to a point). \$\endgroup\$
    – TonyM
    Commented Mar 27, 2017 at 10:51
  • \$\begingroup\$ Well, actually I don't have ADC circuit yet, it's still an open case. I started thinking from power supply; I thought "it would be nice to protect the device from wrong battery placement", but then I thought "but will it make my ADC meas. worse?" - so the question is general: does non-switching transistor introduce any noise? Or is more like a resistor? \$\endgroup\$
    – zupazt3
    Commented Mar 27, 2017 at 11:39
  • \$\begingroup\$ More noise is going to come from your power supply and regulators first. Your MCU digital circuitry too if you use an onboard ADC. Deal with the worst offenders before dealing with the small fry. With 12-bits, it won't even matter. Plus the PFETs its at the input of the first regulator anyways. You're splitting hairs. \$\endgroup\$
    – DKNguyen
    Commented Feb 28, 2019 at 15:20
No, there isn't. In such low power applications, conducting FETs are essentially transparent. There is some concern over the source of the gate voltage and placement of the FET: ideally it should be right where the external supply enters the PC board.
Lets examine VDD sag, due to series FET switch and local bypass capacitor:
The added resistance of FET switch will reduce the VDD to ADC, and to the VREF. Can you accept that?
The 100Ohm to ADC Ref pin causes an I*R error, because Ref pin demands charge as the ADC performs the analog-digital conversion. The average of that charge, over time, is a DC current flow; that current times 100Ohm is the Ref error.
  • \$\begingroup\$ I don't think that FET will reduce VDD to ADC or VRef, as the FET will be placed before LDO voltage regulator. So it will decrease a bit voltage, but that doesn't matter as it is regulated later. Am I right? \$\endgroup\$
    – zupazt3
    Commented Mar 27, 2017 at 21:08
  • \$\begingroup\$ You are right. By the way, how many bits do you plan to use? And what sampling rate? And what is the minimum input level? Using the VDD as your reference to ADC will cause errors, unless the VDD is also used as reference to the Sensor, such as a voltage divider with one resistor a Thermistor, or a bridge for strain-gauges, etc. Does you sensor design include using the VDD as its reference? \$\endgroup\$ Commented Mar 28, 2017 at 2:14
  • \$\begingroup\$ Well, at first I will use built-in ADC in STM32, so 12 bits at 2.4 MSPS powered with 3.3V. Later maybe I will add some ext. ADC. This is general purpose DAQ device, so "general purpose" means compromise between price and quality. But yes, sensors should use the same VDD as the main board. If user powers it differently, well, I think I cannot do a lot with it then. So the user will have to accept errors if powering it from different sources and only connecting GND. \$\endgroup\$
    – zupazt3
    Commented Mar 28, 2017 at 8:27
  • \$\begingroup\$ Part of your design task may be to provide a stable trustable voltage reference, say at 4.096 volts or 2.500 volts. \$\endgroup\$ Commented Mar 29, 2017 at 17:00
  • \$\begingroup\$ Probably that will be needed. Btw. can you suggest any good voltage regulator and p-FET for this purpose? By good I mean good price / quality ratio with a little inclination towards price. \$\endgroup\$
    – zupazt3
    Commented Mar 29, 2017 at 17:53
