I am Embedded Software developer. Don't have much knowledge of hardware side but am trying some hardware stuff.
Is it possible to program AVR (ATMega328p) wirelessly using Bluetooth device (HC-05) and then use the same device for data communication?
I have tried this circuit to power ON HC-05 and HC-05 RESET(KEY) by MCU's GPIO and PIN32 of HC-05 is used to reset MCU during programming. The problem is that whenever MCU reset HC-05 also get switched OFF.
Is there any solution or any other circuit that can program AVR and also can communicate data from other Bluetooth devices?
CIRCUIT FOR HC-05 & ATMega328p
If you're an embedded programmer, you'd pretty definitely be aware of the concept of bootloaders.
Typically, you'd have a minimal firmware (the bootloader) that
  1. runs at boot of your ATMega,
  2. sets up the bluetooth device,
  3. uses it (in any way imaginable) to check whether a firmware update exists,
    · if there's one, receives that and
    · writes it to the flash of the ATMega
  4. jumps to the position of the firmware in flash memory.
Pretty much, classical bootloader with update function.
