These two types of connectors I do not know the name and I would like to.
1. enter image description here
2.enter image description here
  • \$\begingroup\$ Those look like Molex barrier strips and in-line crimp connectors. molex.com/molex/home \$\endgroup\$
    – Trevor_G
    Mar 28, 2017 at 18:15
  • \$\begingroup\$ Look up Euroblock. \$\endgroup\$
    – winny
    Mar 28, 2017 at 20:26
  1. PCB mount screw connectors (ideally, use crimped ferrules on the wire ends with these).
  2. Bullet connectors.
  • \$\begingroup\$ Thanks for the first one but the second one, I can't find anything that looks like the one in the picture I took. \$\endgroup\$ Mar 28, 2017 at 18:22
  • \$\begingroup\$ Is there any indication of the manufacturer on the shrouds of the bullet connectors? \$\endgroup\$ Mar 28, 2017 at 18:29
The connector you are looking at might be the MSTB connector made by Phoenix. The header male header is mounted on the pcb. The plug is a screw type connector. You find these systems in industrial machines where easy replacement of a pcb is important. At the same time the connector remains insulated even when unplugged reducing problems.
