I am working with the Keil compiler in a project using the STM32F769I-DISC1. For debugging I use the ST-Link provided by the board. The idea is to use the on-chip DAC using TIM6 for triggering the output signal.
I need to debug the code and watch the DAC values so I am trying to configure the Logic Analyzer tool inside Keil. I have been looking some documentation but I am still not able to make it work.
I have been working with the ST-Link debugger until now and all the functionality seems to work fine, except the Logic Analyzer.
Here is the configuration:
and here the Trace options:
The clock is the same as my CPU clock.
The last option I tested was also to enable the Debug (SYS) from the STM32CubeMX configuration. But Logic Analyzer still doesn't work.
  • \$\begingroup\$ I've had problems with the Logic Analyzer. I've gone so far as taking a demo that works with the Logic Analyzer and adding my code to it. No true success. I was going to suggest this would be a question for the Keil forums (but I see you have a post there). I'm interested in you finding an answer. \$\endgroup\$ – StainlessSteelRat Mar 29 '17 at 18:26
  • \$\begingroup\$ @StainlessSteelRat, could you please send me or post the example code? I am making a review of the code generated by STM32CubeMX and SWDIO and SWCLK are apparently not initialized there (like all other pins used by the Discovery board). \$\endgroup\$ – osuarez Mar 30 '17 at 6:49
