I am working on a project where I am quite uneducated in the aspects of ESD. Our equipment is automated & grounded and the electronic components which will are loaded into the automation are nested in ESD trays. Once the operator loads the trays with the components into the automation, they are not touched again by humans.
If I am only wearing ESD gloves and am only touching the ESD trays, how much risk is there to damaging the electronic component?
The end product is very low cost and non-technical in nature, and I’d like to minimize the expense of mats, straps, etc.
  • \$\begingroup\$ e.g. If they are unprotected LED's, there is still a risk with phantom yield or field failures \$\endgroup\$ – Sunnyskyguy EE75 Mar 29 '17 at 18:06
  • \$\begingroup\$ ESD gloves should be dissipative. (Surface resistance between 1E6 ohms and 1E9 ohms.) From what i've learned, ESD gloves do not provide any ESD protection by themselves. These gloves are used in case you need to wear gloves (for example, to avoid fingerprints) inside an EPA. (ESD Protected Area.) But, i'm still not 100% sure. \$\endgroup\$ – Marty Mar 29 '17 at 20:56
While you are not likely to give a direct shock to components, ESD control also requires minimizing all electric fields. Triboelectric charging (charging from friction) can generate electric fields with a potential of thousands of volts which can travel through the air. To minimize this potential source of ESD you must control materials around sensitive electronic components and the humidity of the air (more humidity makes the air more conductive). The best way is to use grounding mats, straps ect.
An insulator between two potentials doesn't do much when you have fields that reach into the kV range, in short the best way is to make everything the same potential by grounding.
This being said ESD is about minimizing risk. Industries like medical and aerospace have zero tolerance for risk, you can't have a billion dollar satellite fail because someone zapped a component that cost a few dollars. If a production line is having failures or cannot tolerate the chance of a product failing in the field then ESD is a risk factor. The hard part is ESD failure is dependent on the component and the field and both of these are highly variable and makes the risk difficult to determine. The biggest problem ESD is an unknown risk factor so the best way to eliminate the risk is to ensure all fields are zero.
It sounds like your application will tolerate some risk, you need to balance the costs of ESD control with the costs of failure, since I don't know what your failure rate is I cannot speak for one or the other.
NASA\JPL implement some of the strictest ESD controls, check out this article on best practices. You will have to decide on what works for you, but make sure you understand how ESD problems arise and how they need to be controlled, then find out what works for you because ESD control comes with a time and capital costs.
  • \$\begingroup\$ The link to the JPL article results in an FTP download request for a .doc file, in case anyone is surprised by their FTP client firing up. \$\endgroup\$ – Andrew Morton Mar 29 '17 at 18:21
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
