19
I'm guessing it's a Faraday cage around the receiver, but don't know why they might need one. Is there some sort of common interference around 38kHz (their operating frequency)?
It's the only component I think I've used that gets this special treatment. A larger cage may be around one in a VCR, and a little baby cage sometimes appears around the standalone PC mount component:
PC mount
Thanks for your insight!
    \$\begingroup\$ I swear I've seen this question before \$\endgroup\$ – Voltage Spike Mar 30 '17 at 3:56
    \$\begingroup\$ Because it holds the lens down? \$\endgroup\$ – Ignacio Vazquez-Abrams Mar 30 '17 at 7:41
  • 18
    \$\begingroup\$ IR receivers are the Hannibal Lecter of the electronics world. \$\endgroup\$ – user98663 Mar 30 '17 at 8:03
  • \$\begingroup\$ The answer from @analogsystemsrf is interesting, but it could also not be a faraday cage at all, but rather a light filter to make the diode more omni-direction and less sensitive to swamping from head on signals. \$\endgroup\$ – Trevor_G Mar 30 '17 at 13:12
  • \$\begingroup\$ Ignacio no, it doesn't... \$\endgroup\$ – Passerby Mar 31 '17 at 3:19
21
[ added 2_D resistor_grid methodology for exploring shielding topologies ]
You want that IR receiver to respond to photons, not to external electric fields. Yet the photodiode is a fine target for trash from fluorescent lights (200 volts in 10 microseconds) as the 4' tube has that restrike-the-arc action 120 times a second. [or 80,000 Hertz for some tubes]
Using the parallel-plate model of capacitance, $$C = E0*Er*Area/Distance$$ with diode area of 3mm*3mm and distance of 1 meter, the capacitance is $$9e-12Farad/meter * (ER=1 air) * 0.003*0.003/1$$ or ~~ 1e-11 * 1e-5 = 10^-16Farad
What current from a fluorescent light, at 20Million volts/second slewrate? $$I = C * dV/dT$$ or I = 1e-16Farad * 2e+7 Volt/second = 2nanoAmp
That ---- 2 nanoAmp ---- apparently is a big deal (the edge rate, 10 us, is close to 1/2 period of 38 kHz).
The metal cage protects by attenuating the Efield in an exponentially improving manner; thus the further the cage is in front of the photodiode, the more dramatic the Efield attenuation. Richard Feynman discusses this, in his 3-volume paperback on physics [I'll find a link, or at least a page #], in his lecture on Faraday cages and why the holes are acceptable IF the vulnerable circuits are spaced back several hole-diameters. [again, exponential improvement]
Are other Efield trash sources near? How about digitally noisy logic0 and logic1 for LED displays; 0.5 volts in 5 nanoseconds, or 10^8 volts/second(standard bouncing of "quiet" logic levels, as MCU program activity continues). How about a switching regulator, inside the TV; regulating off the ACrail, with 200 volts in 200 nanoseconds, or 1Billion volts/second, at 100 kHz rate.
At 1 billion volts/second, we have 100 nanoAmps aggressor currents. Of course, there should be no line-of-sight between a switchreg and the IR receiver, is there?
Line-of-sight does not matter. The Efields explore all possible paths, including up-and-back-down or around-corners.
HINT TO BEHAVIOR: the Efields explore all possible paths.
From the master of clear-thinking himself, in his own words, I offer the explanation of Mr "Why did the space shuttle explode high over Cape Canaveral?", the gleeful Dr. Richard Feynman.
He provided a 2 year introduction to physics at Caltech, approximately 1962. His lectures were transcribed, very carefully to serve as reference material, [its worth getting these 3, and re-reading them every 5 years; also, the curious teenager will savor the realworld discussions in Feynman's style] and published in 3 paperback volumes as "The Feynman Lectures on Physics". From Volume II, focused on "mainly electromagnetism and matter", we turn to Chapter 7 "The Electric Field in Various Circumstances: Continued", and on page 7-10 and 7-11, he presents "The Electrostatic Field of a Grid".
Feynman describes a infinite grid of infinitely long wires, with wire-wire spacing of 'a'. He starts with equations [introduced in Volume 1, Chapt 50 Harmonics] that will approximate the field, with more and more terms optionally usable to achieve greater and greater accuracy. The variable 'n' tells us the order of the term. We can start with "n = 1".
Here is the summary equation, where 'a' is the spacing between grid wires:
$$Fn = An * e^-Z/Zo$$ where Zo is $$Zo = a/(2*pi*n)$$
At distance Z = a above the grid, thus we are 3mm above a grid spaced 3mm, and using only the "n = 1" part of the solution, we have $$Fn = An * e^-(2 * pi * 1 * 3mm)/3mm$$
Since this Fn is e^-6.28 smaller than An, we have rapid attenuation of the external electric field.
With 2.718^2.3 = 10, 2.718^4.6 = 100, 2.718^6.9 = 1000, then e^-6.28 is about 1/500. ( 1/533, from a calculator)
Our external field of An has been reduced by 1/500, to 0.2% or 54dB weaker, 3mm inside a grid spaced at 3mm. How does Feynman summarize his thinking?
"The method we have just developed can be used to explain why electrostatic shielding by means of a screen is often just as good as with a solid metal sheet. Except within a distance from the screen a few times the spacing of the screen wires, the fields inside a closed screen are zero. We see why copper screen---lighter and cheaper than copper sheet---is often used to shield sensitive electrical equipment from external disturbing fields." (end quote)
Should you seek a 24 bit embedded system, you need 24*6 = 144dB attenuation; at 54dB per unit_spacing, you need to be 3*wire-wire spacing, behind the grid. For a 32 bit system, that becomes 32*6 = 192 dB, or nearly 4*wire-wire spacing, behind the grid.
Caveat: this is electrostatics. Fast Efields cause transient currents in the grid wires. Your mileage will vary.
Notice we only used the "a = 1" part of the solution; can we ignore the additional parts of the harmonic/series solution? Yes. With "n = 2", we get the attenuation * attenuation, and "n = 3" yields atten * atten * atten.
EDIT To model more common mechanical structures, to determine the ultimate trash levels as an Efield couples into a circuit, we need to know (1) the impedance of the circuit at the aggressor frequency, and (2) the coupling from a 3_D trash aggressor to a 3_D signal chain node. For simplicity, we'll model this in 2_D, using the available grid_of_resistors
| improve this answer | |
  • \$\begingroup\$ Am guessing the center pin is gnd, which would extend inside to support the chip substrate. Would that not be shield-enough? Am also suspicious that the frame "X" blocks the head-on optical path...could it be an optical diffuser ? \$\endgroup\$ – glen_geek Mar 30 '17 at 16:43
    \$\begingroup\$ Thank you for the mathematically complete response, the good explanation, and the delightful drawing of marauding electric fields! \$\endgroup\$ – R Zach Mar 31 '17 at 4:57
  • \$\begingroup\$ For successful embedded systems, all the interferers should be identified and quantified, so risks are known up front. In building tools to do this identify/quantify, I work with these issues every day. I watched a team self-destruct, as they ignored feedback risks in an IR receiver. Whether on PCB or on silicon, the need to attenuate trash by 100dB or 150dB is often there. Without identifying and quantifying the phenomena, its just punt-and-hope. To decide to use extra layers, or extra PCB space, or 10 more pins on silicon, one needs good cause. Extreme fidelity requires attention. \$\endgroup\$ – analogsystemsrf Mar 31 '17 at 14:06
    \$\begingroup\$ +1 For referencing and quoting "The Feynman Lectures on Physics" \$\endgroup\$ – jose.angel.jimenez Apr 5 '17 at 8:45
6
The answer is quite simple.
When the PD is receiving a small signal at greatest distance, the PD may only be receiving <1uA and thus even with 60 dB gain with AGC IR Rx has >1MΩ impedance making it sensitive to stray E-fields picked up the the area of of the detector and wires.
Shielding it on the outside may compare well to Sharp/Vishay's shielding on the inside, but shielding is necessary due to the high impedance to extend the range of detection to perhaps 50m using the appropriate IR 5mm emitter by shunting stray E-fields.
One can tell it is IR due to the daylight blocking filter and 3 pins needed for the integrated BPF AGC and ASK detector.
