I'm trying to simulate a DC motor with simulink. The problem is that I don't know how to take a load torque into account. If the DC motor drives a wheel with constant velocity, there will be a constant frictional force working against the DC motor. How would this be implemented in a DC-motor simulink simulation?
I have tried subtracting a load torque in between the two transferfunction blocks but then the simulated motor speed is always goes negative.
    \$\begingroup\$ Constant torque means constant current. I don't see you modelling current yet, it's all hidden in K. \$\endgroup\$
    – Janka
    Mar 30 '17 at 12:18
  • \$\begingroup\$ @Janka I believe the current is modeled by the \$\frac1{R+Ls}\$ part. \$\endgroup\$ Mar 30 '17 at 12:54
  • \$\begingroup\$ "there will be a constant frictional force working against the DC motor" is an error. Retarding force on a motor is load + friction + windage. Friction and windage effectively go to zero at zero speed. (For your purposes). friction + windage go negative at negative speeds. Each follow some curve on ether side..... \$\endgroup\$
    – Trevor_G
    Mar 30 '17 at 14:37
Your block Kt/(R+Ls) is torque. V/(R+Ls) is your current. Kt is torque per amp (Nm/A). You simply add a value after Kt/(R+Ls), if it's constant. Unfortunately, many loads are speed or position dependent and then it get's much more complicated (math wise). Model-wise it's pretty easy.
If you apply a high enough constant torque to a stalled motor, you will end up turning it in the opposite direction, so a negative speed may well be physical. For starters, try applying less load torque and see what happens.
    \$\begingroup\$ Thanks! I tried adding less torque and the results gave much more sense now. But as i've realized the load torque should not be a constant value from the beginning (in the case of a wheel starting to turn in contact with the ground). The static friction increases as the forward force increases until the wheel starts turning. Is there a way to make an input like this in simulink? (an input that increases by the same amount as the forward force/torque and then stops once it reaches a given maximal value) \$\endgroup\$
    – thosava
    Mar 31 '17 at 16:13
