I recently bought what I thought it would be an ATtiny85. After a few unsuccessful tests, I discovered (guess what?) true ATtiny85 had "ATtiny85" printed on it, like this one:
Mine is this one:
The printing says:
ATMLU324
16B 1
Z8J0534B
I searched for a datasheet, but all I found was datasheet sites searching for it too. What is this chip?
    \$\begingroup\$ Where did you buy it? \$\endgroup\$
    – marcelm
    Mar 31, 2017 at 13:11
  • 8
    \$\begingroup\$ @GabrielRado So, with > 95% probability this is a counterfeit or garbage, or something that left the factory in ways it shouldn't have, for all we can tell, OR this is really a custom Atmel product that they made for a bigger customer and they had overstock and sold that. And you bought something that might work like an Attiny85 in some ways, but not in some others. These ICs costs cents new from large distributors. I recommend throwing yours away. You've been scammed. Don't buy electronic components from questionable sellers. \$\endgroup\$ Mar 31, 2017 at 13:19
  • 4
    \$\begingroup\$ Oh by the way, the crime here is called fraud (against you), and counterfeiting (against Atmel). Atmel might be nice to you if you tell them. \$\endgroup\$ Mar 31, 2017 at 13:21
    \$\begingroup\$ @GabrielRado Please include answers to extra questions in your question as well, so anyone trying to help you doesn't have to wade through the comments :) \$\endgroup\$
    – marcelm
    Mar 31, 2017 at 13:36
  • 8
    \$\begingroup\$ "Wanted organ for our church, got a package of strange meat. Would not buy again." \$\endgroup\$ Mar 31, 2017 at 15:28
19
It looks for all the world like an Atmel AT24C16B, a 16kbit two-wire serial EEPROM chip.
In particular, page 14 of the datasheet has this diagram explaining the markings on the DIP version of the chip:
                      Seal Year
                       |  Seal Week
   A   T   M   L   U   Y   W   W
   1   6   B       1
   * Lot Number
  Pin 1 Indicator (Dot)
Y = SEAL YEAR             WW = SEAL WEEK
 6: 2006  0: 2010          02 = Week 2
 7: 2007  1: 2011          04 = Week 4
 8: 2008  2: 2012          :: : :::: :
 9: 2009  3: 2013          :: : :::: ::
                           50 = Week 50
                           52 = Week 52
Maybe you were simply sent the wrong part by mistake. Or maybe the seller tried to scam you with a cheaper (or counterfeit) part.
    \$\begingroup\$ ... and then the seller mysteriously disappeared from the market place they sold the wrong chip on? While I value your belief in the good in mankind... \$\endgroup\$ Mar 31, 2017 at 13:28
  • 5
    \$\begingroup\$ @MarcusMüller Or they went out of business because they kept sending customers incorrect parts. You can't just conclude malice from the information we have now. \$\endgroup\$
    – marcelm
    Mar 31, 2017 at 13:34
    \$\begingroup\$ @marcelm fair point, but I'm trying to think of likelihoods here, and that tells me that parts labeled as something else sold from a Argentinian marketplace website with a Brazilian domain selling chips with exactly that marking are available from aliexpress with a seller that disappears isn't a good basis for assuming they did a mistake \$\endgroup\$ Mar 31, 2017 at 13:44
    \$\begingroup\$ @MarcusMüller Fair enough. And I agree it's certainly possible that it was a scam. No way to be sure though :) \$\endgroup\$
    – marcelm
    Mar 31, 2017 at 14:39
    \$\begingroup\$ @marcelm high five :) full agreement \$\endgroup\$ Mar 31, 2017 at 14:41
First of all, I believe it should read ATMLU924.
There are multiple sites online that suggest these are knock-off serial eeproms, see
You could try hooking these up and see if you can still use them as memory. However, if they were advertised as ATtiny85, it's likely that somebody scammed you, unfortunately.
    \$\begingroup\$ I went by the picture OP posted. Compare the 9 with the 3 further down. \$\endgroup\$
    – FRob
    Apr 1, 2017 at 10:18
  • \$\begingroup\$ Fair enough, they do look slightly different. You may be right. \$\endgroup\$
    – marcelm
    Apr 1, 2017 at 12:35
Multiple pictures with that same code show up on websites like Alibaba, claimed to be an attiny. It's a counterfeit of some kind, maybe it is an attiny inside and will work like one, maybe not. Only way to find out is to try to program it.
    \$\begingroup\$ and not even that would prove it works like an Attiny – it might misbehave in strange ways. \$\endgroup\$ Mar 31, 2017 at 13:20
    \$\begingroup\$ @marcusmüller definitely, it could even be an attiny that failed QA and got stolen instead of destroyed/recycled. Whatever it is, it's probably not worth using \$\endgroup\$
    – mbrig
    Mar 31, 2017 at 13:24
