What is the difference between those two circuits, when only output node is changed?
Is there any changes in the output resistance, voltage gain, or somewhere else?
    \$\begingroup\$ What you should read more into would be the "Difference between high-side and low-side MOSFET Drivers". I believe you will find most of your answers there. \$\endgroup\$ – 12Lappie Mar 31 '17 at 13:45
    \$\begingroup\$ Is there any changes in the output resistance, voltage gain, or somewhere else? Yes, do the small signal analysis of both and you will know. \$\endgroup\$ – Bimpelrekkie Mar 31 '17 at 14:01
  • \$\begingroup\$ Neither of your circuits has an input indicated, so I don't see how either one can be considered an amplifier. \$\endgroup\$ – The Photon Mar 31 '17 at 17:42
  • \$\begingroup\$ @ThePhoton: You know what I meant. I know you could probably and most possibly quess where I am aiming with this question. \$\endgroup\$ – Keno Mar 31 '17 at 21:08
Yes, there is a huge difference between those two circuits. When the output voltage is taken from the source terminal we have a Source Follower (common-drain amplifier). The Output voltage is Vgs lower than the voltage at the MOSFET Gate. The voltage gain is less than one (\$A_V = \frac{R_4}{\frac{1}{gm} + R_4}\$) and Rout is 1/gm (low).
The second circuit is a classic Common Source with Source Degeneration resistor (R4). The voltage gain is equal to \$A_V = -\frac{R3}{R4+ \frac{1}{gm}}\$
The voltage gain is negative but usually, we ignore this "minus" sign. Because this only informs us about 180-degree phase shift between Vin and Vout. When the voltage at the MOSFET Gate increases, the drain current also increases. The current in the drain resistor (R3) increases (ID = IR3) which increases the voltage drop across it (across R3, VR3 = IdR3) so the drain voltage decreases (Vd = Vdd - IdR3) which is 180 degrees to the change in gate voltage. And the output resistance is Rout = R3.
| improve this answer | |
  • \$\begingroup\$ Is it true that with "Rs" (by making negative feedback to mosfet) in the circuit "Q" is to be stabilized? I mean if dc bias conditions are applied for "Q" to be in the saturation region and gate voltage for some reason increases, "Q" stays unchanged - because of the negative feedback. Is this true? \$\endgroup\$ – Keno Mar 31 '17 at 21:26
  • \$\begingroup\$ Or this applies if temperature changes - thermal stability? \$\endgroup\$ – Keno Mar 31 '17 at 21:44
This is the classic 0/180 balanced output reversed-phase amplifier. You use it in certain audio amplifiers. If the active-device is biased for high gm (transconductance), the bottom voltage swing is nearly identical to the top voltage swing.
  • \$\begingroup\$ Which "this" are you looking at? OP showed two entirely different amplifier circuits. \$\endgroup\$ – The Photon Mar 31 '17 at 17:41
  • \$\begingroup\$ Could you maybe explain this in more detailed manner? I know what you want to explain but I would be greateful for more detailed answer. \$\endgroup\$ – Keno Mar 31 '17 at 21:12
as there is no input signal, those questions are not answerable.
after that, you will need to know about the characteristics of the input signal to answer your questions with confidence.
  • \$\begingroup\$ How many times do I have to tell you this is only a simbolic circuit. Of course there is an input signal! \$\endgroup\$ – Keno Apr 1 '17 at 16:17
