I want to set the lower and upper cutoff frequencies of a single supply inverting op amp. Is my understanding of the frequency response correct? I also have some questions mixed in:
  1. The low frequency cut off is \$ \frac{1}{2 \cdot \pi \cdot C_2 \cdot R_3} \$. To be more accurate, I could find the output impedance of the Vin source, and add this to R3 in the calculation.
  2. For the R1/R2 voltage divider, I would find the equivalent resistance (5k) of these resistors in parallel. Then the cutoff frequency would be \$ \frac{1}{2 \cdot \pi \cdot 5k \Omega \cdot C_1} \$. Does this cutoff frequency apply to the Vin signal? If so is this the lower or upper cutoff frequency and why? I read in a TI document that R1 and R2 are in parallel from a "noise perspective", and then it referred to the calculation result as the cutoff frequency, so I'm not sure how this cutoff frequency factors in, or if it only applies to noise...
  3. C3 and R4 create the high frequency cutoff with \$ \frac{1}{2 \cdot \pi \cdot R_4 \cdot C_3} \$.
  4. For C_OUT and R_LOAD, where R_LOAD is headphone impedance, is this forming a passive high pass filter, with \$ \frac{1}{2 \cdot \pi \cdot R_{Load} \cdot C_{out}} \$ ? I have seen a comment before that this would be the low cutoff...but it's in the configuration of a passive high pass filter, so I'm confused.
  • \$\begingroup\$ C1 is just a small cap for V+ ripple (LPF ) and R1//R2 can be large = R4 for input DC bias match if high gain, R2 >> Zsource, Cout is big for Rout 20~40Hz \$\endgroup\$ – Tony Stewart EE75 Apr 1 '17 at 4:55
  • \$\begingroup\$ Let me reply you in the morning. \$\endgroup\$ – Jason Han Aug 4 '17 at 14:45
Two. C1 is a noise filter. It does not affect the frequency response of the circuit, but it does affect the frequency profile of the noise present at the opamp non-inverting input. Note that this includes power supply noise and ripple, induced interference, etc., not just the noise caused by the two resistors.
Four. Yes, C4 and the load form a high-pass filter.
From my point of view, the terms "Low Cutoff" and "High Pass Filter" mean exactly the same thing.
C1 simply bypasses the reference voltage that feeds the (+) input of the op-amp. So long as the break frequency is significantly-lower than any ripple frequency that might be on the Vcc or Vdd line, all is good. I generally go overboard and make the value of both C1 and R1 & R2 very high.
As you suggest, C2 & R3 form a High-Pass filter. Likewise, C3 & R4 form a Low-Pass filter.
Note that Cout can be another High-Pass filter if the value of the load impedance is known. If this is not desired, make Cout large enough that the break frequency is much lower than your lowest desired frequency.
