-1
I have been using them to simulate my s-parameter tests, but I'm not sure what they are exactly. Are they simply some impedance that simulates an infinite transmission line?
  • \$\begingroup\$ Show a schematic, or a screenshot of the ADS window. \$\endgroup\$ – analogsystemsrf Apr 2 '17 at 1:51
They affect the circuit exactly as if they were 50 ohm resistors (or whatever impedance you specify). This is the same effect an infinitely long 50-ohm characteristic impedance transmission line would have on the circuit.
They also tell the program where to calculate output signals when doing S-parameter simulations.
They might also (I don't remember this detail) also be used to generate stimulus signals for S-parameter simulations, (For example, so you not only get the \$S_{21}\$ but also get \$S_{12}\$) but if you want this behavior it would be more clear to use a Port device than a Term.
| improve this answer | |
  • \$\begingroup\$ You are correct, they are also used to generate stimulus for the s parameter simulation. \$\endgroup\$ – Mike Apr 2 '17 at 17:20
