I'm repairing an ECU board from a SCANIA generator.
It works with 24Vdc, and on the last maintenance the technician powered it with 220Vac, so it blew up some components.
I've managed to replace the burned components, and the board communicates with the controller and PC, everything looks good, except for a "small" problem.
There's a P-Mosfet circuit at the input that blew up, which is heating up a lot on normal use (it reaches at least 80Cº, can'ts say for sure, i don't have a good temp. sensor).
It's really difficult to reverse engineer because i only seee one side of the board and it's very dense (too may components), here's what i could follow:
Some components that where affected: Q1 shorted, M1 shorted, C3 and C2 (tantalum rated at 20Vdc) shorted, and R2 open.
I replaced all those components and the board now "works". The replacements i used are the same components, not some aproximated equivalent.
Point A is where most loads are connected, and is controlled by an input pin, where 24V on Pin = ON, 0V on Pin = OFF.
The curious thing about the circuit that i cant figure out:
When ON: Point A measures 7Vdc! So the mosfet is dropping 17V, so to me the fact that it's heating up a lot makes sense. (also makes sense that the tantalum capacitors at the output C2 and C3 are rated at 20Vdc)
Even though everything is working, it worries me that this mosfet doesn't seem to be working on normal specs.
This is leading me to think that there has to be a closed loop between "unknown circuit" in point A and "unknown circuit" in Q1 base, and somehow use the mosfet in it's linear region to drop voltage as a function of the load (maybe?). Maybe some other part was destroyed that i can't find, and it's driving the mosfet to a very high voltage of 17V drop instead of maybe 10V or less
If the mosfet was being used as a simple switch, the voltage across draing-source would never be 17V, no matter the load.
Anyways, my question here: Is there any "typical" circuit that uses a mosfet like this, to drop voltage AND turn on/off? Something like a "voltage dropper" perhaps.. If so can you give me example circuits so i can keep searching inside the board to find what the problem is (or if its a problem at all).
Keep in mind that this device is working fine on my bench, with nice temperature. The ECU goes mounted next to a generator where the temperature is at least 50-60Cº, so even if this works here heating up so badly, i don't think it will survive much on it's working conditions. Any ideas would help here.
    \$\begingroup\$ There must be something else connected to the MOSFET's gate to pull it down or it will never turn on ... \$\endgroup\$
    – brhans
    Apr 3, 2017 at 12:51
  • \$\begingroup\$ The mosfet doesn't necessarily drop 17v to measure 7v at A, Maybe it works in the switching mode as a bcuk regulator... \$\endgroup\$
    – iMohaned
    Apr 4, 2017 at 3:21
  • The measured 7V is not incompatible with the observed 5 and 3.3 V outputs in your scheme (see last bullet); it is still working but very inefficient.
  • The MOS seems to act as a series-connected linear regulator. Maybe it shall protect/regulate when voltage goes up on 24V during charging.
  • The transistor Q1 may be there just to switch on/off, but I believe it is part of a circuit that regulates and protect from overcurrent (see figure, taken from here).
  • R2 is evidently a shunt: it is 0.4ohm, that would drop a voltage around VBE values (i.e. 0.5-0.6V) for about 1.4-1.5A; it is consistent with the MOS heating up a lot. However, R2 seems on the "wrong" side, i.e. upstream; but also the MOS is of P polarity (instead of N)...
  • 17V across the MOS is a lot; probably it is designed for minimum VDS. From this the reason for a P MOS; with negative VGS, not subtracting volts from VA (or at least, this is what I guess was in designer's head). Maybe a reference zener you do not see is gone, and the MOS is taking the whole voltage available, going to the minimum VA=7V allowed for the buck-reg to work.
Sorry, no other ideas.
The MOSFET could be part of a voltage regulating circuit, but the part of the schematic shown looks like a current limiter: When the voltage across R2 becomes high enough to turn on Q1, it reduces the gate voltage enough to limit the current through the MOSFET.
The heating may be due to excessive current. Check the voltage across R2. If the R2 voltage is around 0.6, it's probably reached current limit. If this is case, you might have additional damage to components or circuits connected to "A" that is causing added load. The shorted tantalums indicate they saw excessive voltage when the MOSFET failed with 220VAC applied.
Last, good design practice is to derate tantalum capacitor voltages to 60%, so the nmormal operating voltage at "A" probably shouldn't be higher than 12V.
