So I'm just getting my feet wet with CPLDs, in fact I programmed a chip successfully for the first time last night (success being programming it with the correct program, not the one recovered from it which is what I think I did the day before), and I got an output pin set to high meaning I can light an LED (with appropriate resistor).
Then I wanted to make it flash, and set about using the internal oscillator. I'm using Quartus Prime, and found the oscillator and tied it to an input pin that I left unassigned for the OSCENA, thinking that would default high. I fed that as the clock into a 74xx counter and used the high bit to drive the LED, but no joy.
how do I ensure a wire is high in the schematic builder?
From research this seems to be quite easy using Verilog or VHDL and found examples, but I am a software developer so doing so holds less interest for me as for such a simple use case it boils down to something akin to a for loop.
This is what I've cooked up so far, using the guide available here to make the oscillator available:
The guide says "make a wire, give it a logic value of 1" and that doesn't seem possible here, though I checked the Verilog provided and it seems they're basically hooking up a switch, so I did the same.
From what I understand the 7457 is 1:60 frequency divider, and I know that even dividing this oscillator's clock by 60 isn't going to help on the human scale, I thought I'd see something when running a simulation, but that seems to not be the case.
Simulation setup:
And the result, showing the clock output as "unknown" (too fast?!) and the LED as logic low.
So, any pointers on what I'm doing wrong?
