We are trying to design a PCB antenna for wifi application. This is a verified PCB antenna design for 2.4 GHz band from texas instruments.
Their PCB's stack up is like this:
--------- 15 um copper layer
1.47 mm substrate FR4 with 4.2 Dielectric coefficient
when I simulate this exact design in HFSS with exact PCB model of TI's, it gives fine results. s11 has a down peak at 2.45 GHz and VSWR is below 1.2 between 2.38 and 2.52 GHz.
However, when I use the same antenna design with our PCB stack-up:
--------- 18 um copper layer
0.87 mm FR4 with 3.95 Dielectric coefficient
the center frequency of the antenna shift very much above 2.7 GHz. Of course I figured it is related to difference in substrate height and dielectric propoerty but I don't know how should I modify this. I feel like I have to decrease the width of the lines somehow, so I did. But it did not wok, infact, it shifted the center frequency to 2.8 GHz. Can you suggest me some intuitive approach to modify this antenna so I can use it in my wifi application? I would not ask this if I have much time but I don't. I need to figure it out in a week I guess.
