Say I have a 12V battery hooked up to an inverter (assume no inefficiency). I guessed that if a 1A, 120V draw was placed on it, because 120W was pulled from the inverter, it would pull 120W, and therefore 12V/10A from the 12V battery. Is this assumption flawed?
    \$\begingroup\$ Yes, because your 100% efficiency assumption is not true. \$\endgroup\$ Commented Apr 4, 2017 at 15:23
Your assumption is true, power is conserved if you have a 'magical' inverter that converts energy at 100% efficiency.
For a real world inverter however, you need an efficency rating, usually 80-95% but could be lower. For a real world inverter the power out can only be lower than the power in, and if your doing any kind of sizing its better to estimate the efficiency with a lower number.
$$ P_{in}*Efficency = P_{out} $$
