how can I prevent a counter based on JK-FF (up-counter, up/down-counter) from jumping back to zero after it reached the maximum.
For Up-Counter: It should count up until it reaches maximum and stay there until I reset the JKFF.
For Up/Down-Counter It should count up until it reaches maximum and stay there until I reset the JKFF. It should count down until it reaches minimum and stay there until I reset the JKFF.
Thanks for your help!
Disable the counter when the max is reached. You can do that by passing the clock through a AND gate down to the clock input. The other input is the internal state based enable which you create with an n-input AND gate for detecting max and a n-input NOR gate for min.
When clamping you add the (possibly inverted) direction input pin to the and gates:
  • \$\begingroup\$ Insertion of some gates into the clk line is not good. Better is use an enable input on the Counter \$\endgroup\$
    – Roman
    Apr 5, 2017 at 9:03
