I've been tasked with designing a three phase system to be sent over to the US and have encountered a few questions along the way.
My system will be hooked up to a 208Vac three phase socket and most devices that I am using in my system are happy to be powered by the line to neutral voltage that you get from 208V three phase of 120Vac. However there are two devices that require a minimum of 180Vac (I guess they are not intended to be used in the states).
I understand that the line to line voltage in 208V three phase is 208Vac which would be be fine for these devices of which I have two.
My question is, are there any adverse effects when you wire up a system this way or is this perfectly standard practice. I guess that you can probably tell that my experience in this field is fairly limited.
Any help would be greatly appreciated thanks.
I have attached a picture of what I intend to do for clarity.
