I am a beginner working on my Arduino-based proximity sensor array project, like this one. I have already tested the functionality with single HC-SR04 transmitter/receiver and now I would like to build an array with, let’s say, 9 columns and 3 rows (27 transmitters, 27 receivers to connect to 54-pin Arduino Mega).
That HC-SR04 has a measure range from 2 cm to 400 cm with precision up to 3 mm (could be even higher with thermistor) and I want all of this to be downscaled: measure range from ideally 0 mm (3 mm are acceptable) to 30 mm with precision of ideally 0.1 mm (acceptable is 0.3 mm).
And I need these T/R merged into one casing – like this and much smaller, let’s say 3 mm of width, but smallest available transceivers are about 8 mm wide.
Is there some physical limitation? Or is it because there is just no need for it?
Thank you.
Ultrasonics are defined by scale. The smaller it is the larger the frequency needed and the less amplitude, range and sensitivity you can achieve for a given drive voltage.
That translates into a trade-off. Smaller devices are possible, and probably even available, but the cost will go up due in part to fabrication costs and being a much smaller marketplace.
