I have been working on a project in which I have been using an Howland AC current source (it has an AC voltage source in it) as a current source. But as an upgrade, I need a current of same sort which can be made using a 5VDC source (battery) and other components.
Objective is to make the equipment portable. Load is variable, so constant current over a wide range of output load is preferred.
