Before I pick a component for a PCB, I am trying to make sure it would not become obsolete in the near future because it's a mess and it happened to us a few times.
How would you check if a chip is going to have at least a few years of life?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityBefore I pick a component for a PCB, I am trying to make sure it would not become obsolete in the near future because it's a mess and it happened to us a few times.
Ultimately, you can't.
Some manufacturers have a policy of supporting chips into the future, and assure customers that they will be available until a certain year, or that you will have (say) 5 years' notice of withdrawal. That's better than no assurance, but if they go belly-up, then a notice period becomes meaningless.
If you can estimate how may PCBs you will make, and can afford the stock, then you could make a one-time buy. This is rarely an option. If your market suddenly exceeds your expectations, than that's a 'good' problem.
Ideally, choose chips that are available from several manufacturers, to the same specification. The chance of them all going belly-up at the same time is small, but the chance of the market changing and causing them all to withdraw for economic reasons is higher. Of course, there are a huge number of 'interesting' ICs that are only available from one source.
You can have an obsolescence plan, to minimise disruption if you lose supply of a vital component, to allow you to mitigate its loss fast. Depending on what it is, write it in C rather than assembler, write it in VHDL rather than a graphic design tool dedicated to the supplier, have extra space and extra power available nearby so that if forced to replace it with components on a daughter board, you're not forced into a bigger re-design.
It only tends to be the military who want 30 year repair or production life. The way 99% of other people work is that a new model of the end equipment (which needs newer components to be designed in) is needed before the components that make up the old one become unavailable. It's a risk, but alongside all the other business risks, most people don't get stung by it.
Texas Instruments is probably lucky to have its own manufacturing plants. I've heard over and over that they'll keep building a chip as long as people are buying it. I'm sure the fine print somewhere says "as long as you buy enough quantity". The "hero" devices will definitely never go away (MSP430G2553, CC3200, and AM335x are a couple).
