The connector on board of kinesis advantage pro keyboard (for usb and rj cables).
This is a JST SH Connector. JST is the "brand"/designer.
Here's the digi-key part. https://www.digikey.com/product-detail/en/jst-sales-america-inc/B7B-XH-A(LF)(SN)/455-2252-ND/1651050 Please note that your connector may be a chinese variant or knockoff, but this shouldn't matter for you.
Here's how you can search for connector types: http://www.digikey.com/en/resources/connectors/rectangular-connectors
\$\begingroup\$ would you happen to know what the male connector is called? Also, if you notice there is the other connector on the left side, would you happen to know what that might be called as well? Thanks. \$\endgroup\$– MunibMar 8, 2020 at 1:36
\$\begingroup\$ @Munib, it seems like "B9B-XH-A(LF)(SN)" + "EHR-9" for left connector and "B7B-XH-A(LF)(SN)" + "EHR-7" for right connector. URLs: digikey.com/en/products/detail/jst-sales-america-inc/… digikey.com/en/products/detail/jst-sales-america-inc/EHR-9/… digikey.com/en/products/detail/jst-sales-america-inc/… digikey.com/en/products/detail/jst-sales-america-inc/EHR-7/… \$\endgroup\$ Mar 26, 2021 at 13:52
\$\begingroup\$ @Munib, I was wrong. It is "B9B-PH-K-S(LF)(SN)" + "PHR-9" for left connector and "B7B-PH-K-S(LF)(SN)" + "PHR-7" for right connector. And "SPH-002T-P0.5L" connector contact for both. I bought them and they fit perfectly. I will crimp them later and add a detailed answer. \$\endgroup\$ Apr 8, 2021 at 12:21
It is B7B-PH-K-S(LF)(SN) + PHR-7 + SPH-002T-P0.5L from JST manufacturer for the right connector (that circled in red on the question photo).
And it is B9B-PH-K-S(LF)(SN) + PHR-9 + SPH-002T-P0.5L for the left connector.
I bought them and they fit perfectly (but I didn't crimp it yet).
Specification for JST PH connector series: https://www.jst-mfg.com/product/pdf/eng/ePH.pdf
Thanks to @Kevin for pointing out the JST manufacturer.
P.S.: USB cable is probably a "Copartner E119932".
On this new photo there are original Kinesis Advantage Pro keyboard cable with connector on the left and new one (bought by me) on the right:
