I am learning to work with LTSpice. After I did my transient analysis, I established the .four command, but I don't know how to change the number of harmonics from the default which is 9 in LTSpice, any insights are appreciated. Thanks in advance.
\$\begingroup\$ Have you thought of first consulting the most immediate resource available: the help? It's rather spartan, but I believe you'll find most of what you need in there. \$\endgroup\$– a concerned citizenApr 9, 2017 at 6:37
1 Answer
.FOUR -- Compute a Fourier Component after a .TRAN Analysis
Syntax: .four <frequency> [Nharmonics] [Nperiods] <data trace1> [<data trace2> ...]
If we define [Nharmonics] ,then analysis includes that (Nharmonics) number of harmonics.
Example .four 1kHz 50 V(out) It will find THD with 50 harmonics.
Reference: http://ltwiki.org/index.php5?title=FOUR_dot_command
