Most electronic devices use constant voltage source as power supplies. Why do LEDs require constant current source?
\$\begingroup\$ Most devices start with a voltage and then limit the current with a resistor. LEDs need to limit the current through them so a 'constant current' feed works well for them to control brightness. \$\endgroup\$– JIm DeardenCommented Apr 9, 2017 at 12:15
\$\begingroup\$ @JIm Dearden, I don't quite get it. If the current is constant, how can the brightness be adjusted. I presume brighter the LED, higher the current consumption? \$\endgroup\$– user768421Commented Apr 9, 2017 at 12:17
\$\begingroup\$ The brightness is controlled by the current - you can adjust the size of a constant current. \$\endgroup\$– JIm DeardenCommented Apr 9, 2017 at 12:19
\$\begingroup\$ Look at the VI curves on data sheets. CC means for a given brightness - more I = more brightness. \$\endgroup\$– Russell McMahon ♦Commented Apr 9, 2017 at 14:12
Oh, you can drive an LED with a constant voltage. It's only that this voltage has to be in a very narrow band, depends on chip temperature, and is difficult to regulate.
Look at the I/U chart of a small power white LED. See how the current varies between 1µA and 10mA (nominal current) in the small band between 2.25V and 2.5V? And how much it depends on temperature? And how the power and the excess heat also vary 1:10.000 ?
So, it's much simpler to look at the current directly. That's why the current is measured and regulated (or simply limited with a resistor.)
Physics determines the I-V characteristics of a diode. It's not like the LED designers/manufacturers have a choice in the matter.
An LED follows the Shockley equation (with added series resistance) like any other diode, albeit with a much lower Is than a silicon diode (resulting in a higher voltage for a given forward current).
A relatively small number of LEDs have been made with an added series device inside the package that allows them to be connected directly to a range of voltages, however they have never been very popular. It adds cost (probably the biggest disadvantage) and limits the LED to a single approximate brightness.
Essentially, the current is proportional to the brilliance whereas the voltage drop is a varying characteristic from device to device.
This is not the only device that requires/benefits from constant current control. But many/most active devices use transistors as the control device and circuits can be most usefully made with these current-varying transistors operating from a constant voltage supply. That's why constant-voltage demand-led current systems are so prevalent.
Also for multiple LEDs, it’s easier to drive them in series than in parallel. Rather than try to determine what voltage to use based on the LED count and voltage drop, it’s easier to get a constant current supply that’s set to the current that suits the brightness you want. All this assumes same model LED.
