7
The PC industry uses a large variety of power connectors which were originally introduced by Molex, using their trademarked (and search-engine unfriendly) brand name "Molex Mini-Fit Jr". This started with the venerable ATX power supply connector shown below:
And continued with a wide variety of other power connectors, notably the 6-pin and 8-pin PCIe auxiliary power connectors used by GPUs (pictures below).
Question:
What is the non-trademarked generic name for this family of connectors?
These connectors are manufactured by several other companies (AMP, TE, FCI, Amphenol, etc) so it's not a Molex-proprietary technology, and I don't think it would have become so widespread if it were anyways. But the other manufacturers list their products under nothing more than a long sequence of digits, like TE's "1586041-6".
I would like to be able to search for connectors in this family without limiting myself to Molex products, which are the only ones that can use the trademarked term "Mini-Fit Jr". There must be a generic term; I'm not a lawyer and don't want to devolve this into amateur legal debates, but my understanding is that in order to maintain a trademark ("Kleenex", "Xerox") there must be a generic term for the product ("Tissue", "Photocopier"); if one doesn't exist then Molex can't enforce their trademark on "Mini-Fit(tm) Jr(tm)"
Additionally, I'm hoping to find the standard that specifies these connectors. After using and examining a lot of them, there appears to be a method to the madness of the keying. You'll notice that some of the pins are square and some are chamfered. Right off the bat that prevents upside-down insertion so long as the male connector (which has a female housing) contains at least one chamfered pin. However it also helps prevent insertion of incompatible connectors: for the vast majority of connectors in this family, each column of two pins has one chamfered and one un-chamfered pin. This means that for a two-row connector with n pins there are 2^(n/2) possible keyings. The ATX connector above is a great example of this. Another example is the 6-pin male PCIe connector shown below:
However there are exceptions! I've come across GPUs before with the connector below that have two chamfered pins in the middle column:
These require a cable that also has two chamfered pins (chamfered male requires chamfered female, but square male will mate with either chamfered or square female) like this one:
Clearly there are a lot of subtleties here. Molex has an irritating habit of not fully describing the connector in the product name; for example the connector above is "Conn Power HDR 6 POS 4.2mm Solder ST Thru-Hole 6 Terminal 1 Port" which does not distinguish between the (at least) two possible incompatible keyings!
All of this brings me to the second question:
Is there a standard that names the possible keyings so that a particular keying can be searched for?
A lot of great information on this topic (but, unfortunately, not the answer to my question) can be found at All about the various PC power supply cables and connectors
5 Answers 5
The EPSV12 v2.0 specification actually names "Molex _____ or equivalent" in the specification so it's a bit more than a de facto but not quite de jure. Several suppliers keep track of equivalency tables for the various part numbers, but not all do. Sometimes politics gets in the way of those tables being complete (for example, DigiKey keeps track of drop-in replacements but I've noticed they don't generally list any for Molex products). Molex helpfully (/s) has a database that will tell you the equivalent Molex part number, but of course it doesn't work in the other direction.
  • \$\begingroup\$ Er yes, but the question is about the name of the family rather than any one specific connector such as the "24-Pin Molex 39-01-2240 or equivalent" in the document you linked. Molex is a huge company and there are several radically different connector families which are all called "Molex connectors" because they're made by Molex. For example, the old four-pin hard drive power connector looks nothing at all like the PCIe connector above, although Molex originated both of them. \$\endgroup\$
    – user4718
    Oct 3, 2017 at 4:29
  • \$\begingroup\$ The four-pin hard drive power connector was an AMP Commercial Mate-N-Lock connector, widely copied. \$\endgroup\$
    – Whit3rd
    Nov 4, 2017 at 9:28
  • \$\begingroup\$ There is no generic name, nor standard. Nor does there have to be. "Connector" is enough for Molex to enforce their trade mark. \$\endgroup\$
    – Finbarr
    Nov 4, 2017 at 14:20
If you want to find equivalent connectors, start with the pitch on any distributors website and start mulling over connectors. Then get the mechanical documents and compare them. More often then not there aren't equivalents.
In my industry, they are just called "4.20mm raster connectors"
  • \$\begingroup\$ Interesting. I checked and it seems that to them "raster connector" is a term for any "rectangular connector". I wonder what does it have to do with "raster" which means "raking" as in "raking the leaves". To these guys, "raster" means "pitch". \$\endgroup\$ Feb 28 at 14:01
    \$\begingroup\$ Yes, in this case raster means pitch, so "4.20mm raster connectors" is the same as "4.20mm pitch connectors". \$\endgroup\$ Mar 22 at 8:26
As there isn't one, I coined it: "Partitioned shroud connectors" and listed them in my Connector Identification utility.
If you like it, I urge you to start using that term.
Specifically, for partitioned shroud connectors with a 4.2 mm pitch, it lists the following:
MANUFACTURER SERIES URL
Adam tech DMF digikey
Adam tech DMF + DMH digikey
Amphenol Minitek Pwr 4.2 (pdf) digikey
Amphenol Minitek Pwr Hybrid 4.2 (pdf) mouser
CNC Tech 4282 + 4281 (1r) digikey
CNC Tech 4282 + 4281 (2r) digikey
Cvilux CP-012 CP-013 CP-014 + CP-011 digikey
Cvilux CP-013 CP-014 + CP-011 (blind) digikey
Molex 5025 (1r) (pdf) digikey
Molex 5025 (2r) (pdf) digikey
Molex 5025 (3r) (pdf) digikey
Molex Mini-Fit BMI (pdf) digikey
Molex Mini-Fit Jr (1r) (pdf) digikey
Molex Mini-Fit Jr (2r) (pdf) digikey
Molex Mini-Fit Plus HCS (1r) (pdf) digikey
Molex Mini-Fit Plus HCS (2r) (pdf) digikey
Molex Mini-Fit TPA2 (pdf) digikey
TE AMP-DUAC digikey
TE VAL-U-LOK (latch 1r) (pdf) digikey
TE VAL-U-LOK (latch 2r) (pdf) digikey
Würth WR-MPC4 (1r) digikey
Würth WR-MPC4 (2r) digikey
  • \$\begingroup\$ Wow! Thank you! I am going to start doing that too! \$\endgroup\$ Feb 28 at 23:38
-1
According to Wikipedia, the technical term is a pin and socket connector, although the vernacular (in my experience) tends to be either "molex connector" or "motherboard/CPU/whatnot power connector".
