I am trying to read register values of DS1302 RTC using a PIC MCU in proteus environment. I have made two simple functions for that purpose, one is for the transfer of DATA to the RTC and other is for receiving from it.
I can only get the correct value of seconds register but all other values (min, days, months etc) are either 0xFF or 0x00. Couldn't find where the problem lies.
I have been tracking the bytes transfer to the RTC using an OSCILLOSCOPE which shows that the data is correctly transferring on the RISING EDGE of the clock. I am not initializing RTC values (because the RTC won't LATCH my data) so I initialize it to the system calendar (option available in proteus).
Here I am sending the address of the second's register (0x81) and receiving the second's value (correct value) from RTC.
Here I am sending the value of minutes and getting (0xFF) everytime.
And for Hour register, I get 0x00. For DATE register I get 0xFF and vice versa.
Here are the two functions through which I am sending and receiving data.
char value=0x00;
void SPI_SEND_DATA(char ADDRESS,char DATA){
delay_us(1);
EN=1;
SSPBUF = ADDRESS; // Transmit ADDRESS
while(!SPI_BUSY_FLAG);
value=SSPBUF; // Clear Bit flag
SSPBUF = DATA; // Transmit DATA
value=SSPBUF; // Clear BF flag
EN=0;
char SPI_RCV_DATA(char ADDRESS){
delay_us(1);
EN=1;
SSPBUF = ADDRESS;
SSPBUF=0x00; // Start the SCLK
while(!SPI_BUSY_FLAG); // Recieve data
value=SSPBUF; // Store the recieved Byte
EN=0; // Fininsh Reading
return value;
Here is how I am initializing the clock in proteus automatically and the clock ticks quite fine.
I have also attached the full project code and simulation file of proteus, in case anyone want to try it. Kindly find in the attachment herewith. Full Project files
Any help/suggestion would be appreciated.
EDIT: I tried the same code on MAX6902 [the only thing I changed is; I have inverted the ENABLE pin because according to the MAX6902 datasheet, its active low] and it worked like charm. The thing is, proteus may have some problem in simulating DS1302.
