Meander antenna
I wondering will above antenna work properly or not because most of the PCB design layout antenna directed in right side & feed length remain unchanged.
As per as I know, feed length does not affect performance but it's width does.
Here is original antenna layout enter image description here
    \$\begingroup\$ You can, but the performance may or may not be what you want, depending on the materials, dimensions and frequencies involved, of which we have no knowledge. \$\endgroup\$ – PlasmaHH Apr 11 '17 at 14:59
  • \$\begingroup\$ Antennas are black magic. Computer simulation is the only way to know for sure. Depending on what you are dealing with, as well as the performance you need, you will have to include things like the case in the simulation. \$\endgroup\$ – Joren Vaes Apr 11 '17 at 15:51
  • \$\begingroup\$ That 'ground' on right side looks rather un-ground-y. \$\endgroup\$ – analogsystemsrf Apr 11 '17 at 16:12
  • \$\begingroup\$ @JorenVaes is there any simulation software for this? \$\endgroup\$ – Kapil Singh Rawat Apr 12 '17 at 5:58
  • \$\begingroup\$ @analogsystemsrf it's properly ground but now I make it closer to feed line. \$\endgroup\$ – Kapil Singh Rawat Apr 12 '17 at 6:01
