I'm using the TVN5-2421WI DC-DC converter where I need an output of at least +/-6V (which will then go into 2 LDOs that will drop it to +/-5V), so I'm trying to use the trim pin for this, however the datasheet doesn't specify what value resistor to use: Datasheet: http://docs-asia.electrocomponents.com/webdocs/1341/0900766b81341219.pdf
How do you figure this out? I'm very hesitant to use a potentiometer.
EDIT: I found a datasheet for another DC-DC converter from Traco, and they have a formula for determining the trim output: Datasheet: http://www.tracopower.com/products/ten25wi.pdf What's the likelihood I can use this same formula?
