If I have a transmission line with a reflection coefficient of -0.3, and I feed it an input voltage of 5V, will my net voltage at the reflection point be
(1 - 0.3)*5 = 3.5V
or
(1 + 0.3)*5 = 6.5V
Came across this problem a couple of days ago and I'm still not quite sure whether or not the reflection coefficient being negative makes a difference to the outcome.
Thanks for all the help!
The amplitude at the end is (1+coefficient)A:
From this question, the following animation shows the wave on a shorted transmission line. The coefficient is -1, so the amplitude is (1-1)A=0 :
The other extreme is an open end, were the amplitude is (1+1)A=2A:
  • \$\begingroup\$ Okay, so in this case, given that the coefficient is 0.3, obviously the final answer should be 3.5V \$\endgroup\$ Apr 14, 2017 at 0:04
