I'm working on a solution for 2 devices to communicate with each other over a very short range. A user will be wearing device #1 around their wrist, and in that same hand will be holding device #2. The goal is that the two devices will know about each other at that short range (less than a foot).
I've looked into RFID and NFC solutions, but the cost of readers are more expensive than I'd like for something like this. A lot of RF transceivers are in the right cost range, but the shortest transmit range I could find for RF transceivers was about 10 meters (with no antenna).
Is it possible to shorten the range of an RF transceiver to fit this goal? Or, if that's not something I can do, is it possible to be able to get a relative distance between the two devices and have some code logic to ignore the device outside my desired range?
I'm really new to playing with electronics so a lot of what I'm reading online is going over my head, but I haven't seen anything that can come close to answering this.
  • \$\begingroup\$ Blue-tooth? The TX power can be tuned in some bluetooth modules. \$\endgroup\$ – mkeith Apr 13 '17 at 6:09
  • \$\begingroup\$ in any module where you can access the signal line between the RF amplifier & the antenna (look for a "squiggly PCB trace...that's the antenna"), you could add a pi attenuator to the trace to decrease TX/RX signal levels. Also, you can check signal latency between the devices. Light travels 1 foot in ~0.8ns, double to 1.6ns,then add the delay for one device to sense an incoming packet & reply...not perfect, but with a 1MHZ or faster resolution, you should be able to rule anything more than 10-15 feet away. \$\endgroup\$ – Robherc KV5ROB Apr 13 '17 at 6:49
You can use L+C loops, resonated at some frequency, and trigger the ringing with a sharp edge from some logic device/gate. Simply connect the gate to series LC circuit to Ground. That is the transmitter. For each "1", send an UP_DOWN pulse to the LC resonator. For "0", do nothing. You may need a bunch of start bits, so the receiver knows it needs to pay attention.
For the receiver, use an identical L+C loop, similar size, so resonates at the same frequency. Simply connect the L+C loop to a PeakDetector. For a very simple decoder, clock the PeakDetector output into a 8-bit ShiftRegister (74HC595). Assume 2 start bits (to wake up the Receiver shifting bit-rate clock). You'll also need to define a packet length, and have enough 8-bit SR to clock in that entire packet.
Now. The science part. How much power must you transmit, across 6 inches? Turns out the necessary receiver power depends on your bit-rate and your bit-error rate. Lets compute that minimum receiver power.
To avoid a bunch of multiplications, we'll use the standard method for communication links ----- logarithms, which engineers have chosen to scale up by 10 [for more resolution], and name deciBels to honor Alexander Bell. Here goes.
-174 .......... dBm/rootHertz.....this is Boltzmann's Constant * temperature
+60 .......... dB for a bandwidth of 10^6 cycles/second or 1MegaHertz; this statement of system bandwidth also helps, by cancelling the 'rootHertz'
+20 .......... dB for how much stronger we need the signal to be, compared to the Boltzmann noise; here the signal is 10^(20/10) stronger, or 100X
By adding these, we know how strong a signal, how much electrical energy, we must get from the Receiver antenna: in our case, that L+C loop.
Lets add -174 +60 +20 == -174 +80 == -94dBm. (no multiplication needed)
What next? Now convert from -94dBm to milliWatts. Engineers have defined 0dBm as 1 milliWatt. Thus +10dBm is 10milliWatt. And -10dBm is 0.1 milliWatt. Our -94dBm is -100dBm + 6dB. The -100dBm is 10^-10 weaker than 1mW; the +6dB is 2 factors of 2, or 4.
Our necessary receiver power, -94dBm, is 4 * 10^-10 milliWatts. Or 4 * 10^-13 watts.
What power can we get from a Transmitter, from a logic-gate? Using $$Power = Voltrms^2/Resistance$$, with 0.223 voltsRMS from a logic-gate, into 50 ohm resistor, we get exactly 1 milliWatt, or 0dBm. Peak to Peak, that's 0.632 volts.
Any logic gate can provide that.
Your transmitter is just a logic-gate into a resonant LC series circuit to GND.
Your receiver uses identical LC resonant series circuit, into a Peak Detector, into a ShiftRegister.
If your inductors (the "L") are 2" across, with TX and RX inductors facing each other only 2" or 3" or 6" apart, even given distance^3 attenuation.....now you need to find the math for wireless power transfer. Even with 30dB attenuation, you have plenty of communication link margin.
To reduce power into the TX resonator, use voltage divider: 100 ohms into 10 ohms, or 100 ohms into 1 ohm. Or 1,000 ohms into 1 ohm.
| improve this answer | |
