I have the following logic gates.
To figure out what logic function is implemented, I try to develop the truth table.
A | B | out (I guess, not sure)
1 | 1 |    1
1 | 0 |    ?
0 | 1 |    ?
0 | 0 |    1
I feel like when A=1 and B=1 thenout=1. Also, when A=0 and B=0 then `out=1'. However, I'm not sure about other cases. I wonder if anybody can help.
UPDATE:
When A=1 and B=0 (or when A=0 and B=1), then the output of each block of logic gates might be as shown below.
Therefore the truth table might be like this:
1 | 1 |    1
1 | 0 |    0
0 | 1 |    0
0 | 0 |    1
If my calculations are correct, the logic gates are implementing something like NXOR (or XNOR?). I'm not sure.
    \$\begingroup\$ What do you think it is? Try to redraw the diagram and cancel out the mosfets that you know what value they produce. You know the top only can output LOWs and the bottom HIGHs, so what happens if both? Btw I think what you're dealing here is a latch, so a logic table may not suffice by itself unless that's actually the question. \$\endgroup\$
    – Bradman175
    Apr 13, 2017 at 10:25
  • \$\begingroup\$ @Bradman175 Thanks, I feel like out for the other two cases would be 0 \$\endgroup\$
    – Megidd
    Apr 13, 2017 at 10:29
    \$\begingroup\$ Justify. Not allowed to say whether you're right or wrong. \$\endgroup\$
    – Bradman175
    Apr 13, 2017 at 10:30
  • \$\begingroup\$ I think you need to add out on the previous state to truth table, because out(n) on the next state also will depend on the out(n-1) \$\endgroup\$
    – Roman
    Apr 14, 2017 at 4:08
  • \$\begingroup\$ It's really not XNOR because XNOR gate hasn't feedback rather than in your draw \$\endgroup\$
    – Roman
    Apr 14, 2017 at 5:33
I don't know which element exactly has drawn on the picture, but my truth table looks like:
A | B | OUT(n-1) |    OUT(n)
0 | 0 |   0      |    1
0 | 0 |   1      |    1
0 | 1 |   0      |    0
0 | 1 |   1      |    X
1 | 0 |   0      |    0
1 | 0 |   1      |    X
1 | 1 |   0      |    1
1 | 1 |   1      |    1
But even this truth table I'm not sure that valid, because out doesn't keep it value and A and B can affect to OUT even when Vdd transistor (pMOS) is close .
