The transistor in the following circuit is said to feature \$I_{C} = 1.0mA\$ at \$V_{BE} = 0.7V\$ and \$V_{CE} = 10V\$. If \$V_{A} = 50V\$ and \$\beta = 50\$, find \$V_{B}\$ and \$V_{C}\$.
Attempt:
\$V_{B}\$ Calculation:
\$V_{B} = 10 - 0.7 - 196.5I_{B}\$
\$I_{B} = \frac {I_{C}} {\beta} \$
\$V_{B} = 10 - 0.7 - 196.5 *\frac {1mA} {50}\ = 5.3V\$
\$V_{C}\$ Calculation:
\$V_{C} = 10 - 1 = 9 V\$
How do I incorporate the early voltage \$V_{A}\$ into the calculations?
Early effect (base-width modulation) means that \$I_C\$ current will change his value as \$V_{CE}\$ change, even if \$V_{BE}\$ and \$(I_B)\$ is kept constant.
So we have another source of a nonlinearity.
For your example circuit we have:
\$\beta = 50\$,\$V_{CC} = 10V\$,\$R_C=1k\Omega\$,\$R_B=196.5k\Omega\$; and the Early Voltage is \$V_a=50\$
Without Early effect the DC operation point is:
$$I_B=\frac{V_{CC} - V_{BE}}{R_B} = \frac{10V - 0.7V}{196.5k\Omega} = 47.328\mu A $$
And \$V_B = V_{BE}\$
Hence the collector current (without Early effect) is equal to:
\$I_{CO} =\beta*I_B = 47.328\mu A * 50 = 2.366mA\$
and the \$V_{CEO}=V_C\$ voltage (without Early effect).
\$V_{CEO} = V_{CC} - I_{CO}*R_C = 10V - 2.366mA*1k\Omega = 7.6335V\$.
But if we include Early effect \$I_C\$ current will change.
We have
$$I_C = I_{CO}*(1 +\frac{V_{CE}}{V_a}) $$
$$V_{CE} = V_{CC} - I_{C}*R_C$$
And if we solve this for \$I_C\$ current we will end up with this:
$$\large I_C =\frac{I_{CO}(V_a+V_{CC})}{I_{CO}R_C + V_a} = I_{CO}\frac{1+\frac{V_{CC}}{V_a}}{1+\frac{R_C}{R_O}}$$
$$I_C = 2.366mA\frac{1+\frac{10V}{50V}}{1+\frac{1k\Omega}{21.129k\Omega}} = 2.36641mA * 1.14577 = 2.71137mA $$
where \$R_O = \frac{V_a}{I_{CO}} = \frac{50V}{2.36641mA} = 21.129k\Omega \$
All this mean that Early effect can be model as a resistor \$R_O\$ connected from the collector to the emitter of an “perfect” transistor.
Also, I deliberately skip the fact that the \$V_{BE}\$ value was given for \$I_C=1mA\$. And here we have \$I_C > 1mA\$ so the\$V_{BE}\$ value will also be slightly larger than \$0.7V\$.
  • \$\begingroup\$ So which formula applies for collector current in linear region: this one $$I_C = I_{CO}*(1 +\frac{V_{CE}}{V_a}) $$ or this one $$\large I_C =\frac{I_{CO}(V_a+V_{CC})}{I _{CO}R_C + V_a} = I_{CO}\frac{1+\frac{V_{CC}}{V_a}}{1+\frac{R_C}{R_O}}$$ ? \$\endgroup\$
    – lucenzo97
    Commented Apr 23, 2017 at 18:21
  • \$\begingroup\$ Shouldn't Ico be replaced with Ic? Like this: \$R_O = \frac{V_a}{I_{C}} \$ \$\endgroup\$
    – lucenzo97
    Commented Apr 23, 2017 at 18:47
    \$\begingroup\$ @Keno Ico is a collector current without Early effect (perfect transistor). So if you want to find the Ic current and includes the Early effect. We can use this equation Ic = Ico*(1+Vce/Va) (1) but you do not know Vce, hence we need additional equation for Vce. Vce = Vcc-IcRc (2), and we substitute (2) into (1) and solve for Ic we get this: Ic = (Ico (Va + Vcc))/(Ico* Rc + Va) = Ico * (1 + Vcc/Va)/(1 + Rc/Ro) . \$\endgroup\$
    – G36
    Commented Apr 23, 2017 at 19:29
    \$\begingroup\$ @Keno For the bipolar transistor gm (transconductance) is the slope of the collector current to the base-emitter (slope of the Ic=f(Vbe) function). gm=d(Ic)/d(Vbe) = Ic/Vt = Ic/26mV = 40*Ic, But also gm = Ic/Vt = beta/rbe. We also have anther point view (from T-model). We include transresistance re = d(Vbe)/d(Ie) is a dynamic (differential) emitter resistance (often called "little re") re = Vt/Ie and we sometimes use this approximation \$r_e = \frac{Vt}{Ie}\approx \frac{Vt}{Ic} \approx \frac{1}{gm} \$ but the exact value is gm = beta/((beta +1)*re) \$\endgroup\$
    – G36
    Commented Apr 24, 2017 at 17:58
    \$\begingroup\$ electronics.stackexchange.com/questions/267662/… \$\endgroup\$
    – G36
    Commented Apr 24, 2017 at 18:02
Have you seen a IV plot for a bipolar
What is the Early voltage for this transistor? Consider that very top line: intercepting the left axis(0 volts) at 4mA, and intercepts the 10_volt line at 7.5mA. [ some very clean numbers, used by the artist ] Our deltas are 7.5mA - 4mA = 2.5mA; 10v - 0v = 10v.
Now extend that to the left, from 0v/4ma point. The intercept with Zero current is 10v * 4mA/2.5mA = 10v * 1.6 = 16 volts to the left. Ve = 16 volts
