Im trying to find a part online, but I cant seem to find what I am looking for. Maybe it has a specific name? I am looking for a D-shaft potentiometer that has two selections. One on top and one on bottom. As you can see from the pictures below, the small dial sits on top of the larger bottom dial. The top dial connects to the D-shaft, while the bottom connects to a bronze sleeve that goes around the d-shaft, but isnt connected to it.
This is a 60 year old potentiometer, its possible this was a custom piece and there is no modern equivalent.
enter image description here enter image description here enter image description here
  • \$\begingroup\$ Try ganged potentiometer. \$\endgroup\$ Commented Apr 17, 2017 at 18:04
  • \$\begingroup\$ They ARE hard to find.... and not cheap. \$\endgroup\$
    – Trevor_G
    Commented Apr 17, 2017 at 18:19
There are a couple varieties- some have multiple sections ganged off of one shaft, others have a concentric shaft that allows the two pots to be adjusted independently (for example for fine/coarse adjustment on old-school oscilloscopes). Tek had some wonderful variations that would expand out a waveform when you pulled the shaft out and twisted the knob. There are some modular pots that satisfied the first need, but perhaps not the 2nd (see below photo of a dual modular pot):
I would call your example a dual pot with concentric shaft(s). You can see a smaller version with similar functionality in the photo below (taken from this web page:
If you are looking for a repair part with specific shaft length and finish it may not be easy- finding a donor unit to cannibalize may be your best bet. For production parts, the pot manufacturers will generally make what you need, subject to minimum quantities in the low thousands for some makers. There are a tremendous number of possible variations- length of each shaft, element resistances and tapers, bushing thread and length, shaft D-length or other end finish, etc. Your chances of finding one that is exact are thus rather slim.
