I own some animatronic robots that use solenoid valves to operate their mechanical movements. enter image description here Recently I created a pcb that uses three 8 channel Darlington Arrays ULN2803A to control the individual solenoids and make the robot move. Each Solenoid is 6.7 watts (or about 300milliamps) and 24 volts. The power supply I use is 4.16 amps and 24v. I use an arduino to control the darlington arrays. When I first tested the darlington arrays, the robot moved and it's solenoids were triggered by the darlington arrays, but upon inspection of the board, the darlington arrays began to smoke. I replaced them, and tested them again. I tested them multiple times having similar results, only twice did they work without failing. When they didn't fail, I noticed the chips get extremely hot. This has concerned me, because I know someone who also uses them and has had no heating or failure issues with them. I did not use diodes for the outputs as it says they have built in output clamps diodes. I don't understand how I could possibly be overloading them because they can handle up to 50 volts and 500 milliamps. Is there any output protection I should have used? perhaps addition of some resistors? Thanks
  • \$\begingroup\$ Could you share a wiring diagram (or better yet, a schematic) of exactly what was connected and to where? \$\endgroup\$ – rdtsc Apr 18 '17 at 22:20
  • \$\begingroup\$ Added a schematic view \$\endgroup\$ – Jonathan Kramer Apr 18 '17 at 22:30
  • \$\begingroup\$ Darlingtons are the wrong arrangement, as they don't saturate and they will dissipate horribly -- as indicated by The Photon already in an answer. Each relay is only about \$\frac{6.7\:\textrm{W}}{24\:\textrm{V}}=280\:\textrm{mA}\$. So this can be done with any BJT rated for about half an amp. Since you can realistically expect to achieve perhaps \$V_{CE}\le 300\:\textrm{mV}\$, this is under \$100\:\textrm{mW}\$. So even a TO-92 could do it. But you'd need 24 of them. You'd still need to work out how to drive them. Or get some NFETs (dual SOT23-6 exist.) \$\endgroup\$ – jonk Apr 18 '17 at 23:10
    \$\begingroup\$ you need larger heatsinks on your transistors. or any. to get anywhere near absmax specs... \$\endgroup\$ – dandavis Apr 19 '17 at 2:37
With Vce-sat of maybe 1.6 V (at 500 mA), each darlington will be heated by ~0.8 W when run at maximum current.
If all 8 darlingtons are active at once that's 6.4 W.
Junction-to-ambient thermal resistance is 66 C/W (for some assumed copper pattern on the board).
So with with all 8 darlingtons active at 500 mA, you can expect a temperature rise of 422 degrees.
What this means in practice is: Don't operate more than one or two of the darlingtons at full current at the same time.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
