I'm wondering as to how a system like this:
this
acts, when their thyristors are controlled in various ways.
The converters are simple enough, but I'm wondering how the graph made around the voltage going over the resistor \$R\$ would look like when the thyristors are set top \$0^\circ\$ and \$90^\circ\$ respectively.
    \$\begingroup\$ On-line simulator: plexim.com/academy/power-electronics/thyristor-rect-ind-load \$\endgroup\$ Apr 19, 2017 at 10:41
  • \$\begingroup\$ Thanks, that was a massive help. How does the frequency of the current project to the frequency of the sine-waves; is it directly relatable? (50 hz would mean that one complete sine-wave or two converted "mounds" are 20 milliseconds?) \$\endgroup\$
    – Grak
    Apr 19, 2017 at 10:52
There are several alternative topologies for controlled rectifier bridges. The one in your diagram is called a half-controlled bridge. The associated waveform is shown below.
Here is the description of operation:
The above material is from:F. F. Mazda, Thyristor Control, John Wiley & Sons,1973
  • \$\begingroup\$ it would definitely be helpful to include actual text rather than an image of text. \$\endgroup\$
    – NH.
    Dec 11, 2017 at 16:01
