I have AC on an input (110V, 15A) and need to control the amount of power going to a purely resistive load.
Thyristor controlled by PWM seems like an option, but are there other/better ways to do this?
    \$\begingroup\$ Light dimmers are doing this. \$\endgroup\$ – Eugene Sh. Apr 19 '17 at 22:26
  • \$\begingroup\$ If you mean kHz range PWM or faster, that doesn't work with SCRs. You could call what dimmers do PWM, but most people don't. \$\endgroup\$ – Asmyldof Apr 20 '17 at 0:22
It depends what the resistive load is.
If it's a lamp filament, then a phase shift thyristor/triac solution is suitable, as you probably want to avoid flicker.
If it's a heater, with a much longer time constant, then you can use a 'burst fire' controller, to control average power. That switches a number of complete cycles on and off. The benefit of this is it doesn't generate as much electrical interference as switching in the middle of a cycle would.
| improve this answer | |
TRIAC, or a bidirectional thyristor is a way to do it.
There are two ways of controlling it:
  1. Phase (Angle) Control (PHC), which is how dimmers work.
  2. Zero Crossing Mode
