In this series circuit: Three capacitors in parallel
To determine the voltage dropped across each capacitor
The charge stored in a 2 Farad capacitor
The number of charges stored on the capacitor plates
And Determine what value of a new capacitor C that would store the equivalent charge of all the other capacitors
    \$\begingroup\$ Are you sure those capacitors are in series? \$\endgroup\$ Commented Apr 20, 2017 at 3:58
  • \$\begingroup\$ Have you tried rearranging the terms in your second equation? \$\endgroup\$ Commented Apr 20, 2017 at 4:06
  • \$\begingroup\$ Consider: 1 farad = 1 coulomb per volt, by definition. \$\endgroup\$
    – Phil Frost
    Commented Apr 20, 2017 at 14:17
Those capacitors are in parallel, not series. Whenever you have capacitors in parallel, the total effective capacitance is just the arithmetic sum.
  1. The charge on the 2F capacitor can be calculated using the equation Q=CV. Where C=2F and V=9V because voltages across parallel branches are equal. Thus $$Q_{2F}=18C$$
  2. The total charge can be found using the same equation. Where C=10F which is the total effective capacitance and V=9V. Thus $$Q_{total}=90C$$
  3. Again, total effective capacitance for parallel capacitors is just arithmetic sum. Thus $$C_{total}=10F$$
    \$\begingroup\$ This looks like a homework question. \$\endgroup\$
    – Chu
    Commented Apr 20, 2017 at 6:45
