I am trying to connect to my MacBook Pro the eval board: STEVAL STLCX01V1 from STMicroelectronics so I can try programming the SensorTile.
I am using OpenSTM (System Workbench).
  • \$\begingroup\$ What programmer are you using? That evaluation kit does not include one. \$\endgroup\$ – duskwuff -inactive- Apr 20 '17 at 20:39
  • \$\begingroup\$ I think you are asking if I have a Nucleo board? I do have one a Cradle Expansion Board as well as a Nucleo Board, I just don't have it in front of me. I was hoping the Cardle Expansion Board that has a connector to the SensorTile could be used to program it. \$\endgroup\$ – sAguinaga Apr 20 '17 at 20:43
The cradle expansion board cannot be used to program the SensorTile module. The USB port on this board connects directly to the module -- it's there so that you can program the module to behave as a USB device, and connect it to a computer.
You will need a separate SWD programmer to program and debug this part. Many of ST's evaluation boards, including most Discovery and Nucleo boards, have an integrated ST-Link programmer which will work perfectly. Remove the ST-Link jumpers on the other board, then connect the SWD pins between the two boards with jumper wires. (If you aren't sure of the pinout, check the schematics!)
DO NOT plug the Cradle Expansion Board directly into a Nucleo board using the Arduino shield connector. This won't work, and it might damage one or both boards.
| improve this answer | |
  • \$\begingroup\$ Should OpenSTM and the Nucleo programmer board work on a macOS system? \$\endgroup\$ – sAguinaga Apr 21 '17 at 18:47
  • \$\begingroup\$ Yes. I've worked with ST Discovery boards extensively using OpenOCD. \$\endgroup\$ – duskwuff -inactive- Apr 21 '17 at 18:48
  • \$\begingroup\$ I have a NUCLEO-f401reT6 64 pins + a Nucleo Expansion board (X-Nucleo-IDB05A1) and a development Mac mini. What is the "Arduino shield connector?" I have a 5pin ribbon cable I can connect SWD between the CradleExpansionBoard (CEB) to SWD connector on the Nucleo-64, right? Only connect the Nucleo to my mac mini and not the CEB, right? Next, do I need to figure out if my OpenOCD can detect this Nucleo board? \$\endgroup\$ – sAguinaga May 11 '17 at 19:31
  • \$\begingroup\$ As shown on page 8 of the quick start guide and page 14. \$\endgroup\$ – sAguinaga May 11 '17 at 20:01
