If I want to do a noise analysis I do this in LT spice:
.noise V(adc1) V6 dec 12 0.01 1e9
Where V(adc1) is the voltage for the output node of the analysis and V6 is the source.
Question: Is there a way to have two nodes in the analysis?
Sometimes I copy circuits modify one and and compare the two circuits.
  • \$\begingroup\$ haven't done spice in a while, but wouldn't you have two of these lines? \$\endgroup\$ Apr 21, 2017 at 21:20
  • \$\begingroup\$ No, you can only have 1 analysis line \$\endgroup\$
    – Voltage Spike
    Apr 21, 2017 at 21:21
This can be done with switches and a step parameter that toggles the switches.
You won't be able to integrate the noise over a bandwidth in the plot window anymore, but you can use .meas to output the integrated noise to the error log e.g.
.meas out_noise INTEG(V(onoise))
  • \$\begingroup\$ Can I run this in one sim? or do I have to run the sim twice? If I have to run the sim twice then it's probably easier to change the noise statement \$\endgroup\$
    – Voltage Spike
    May 19, 2018 at 4:03
  • \$\begingroup\$ @laptop2d it is one simulation. \$\endgroup\$
    – DavidG25
    May 19, 2018 at 4:06
  • \$\begingroup\$ @DavidG25 It's actually two simulations, disguised by the .step command. I'm a bit pedantic now, but it's about the same: change a .step or change a .noise card. It's still half-automated, and could be done for more than two I/O. \$\endgroup\$ May 19, 2018 at 6:54
Not having tried this, I can't guarantee it will work... but here is an idea:
Create a behavioral voltage source that acts as a mux between the two nodes, and use a swept parameter to control the mux. Set the output of the mux to be the output node for your noise analyis. Something like this:
BX Vmux 0 V={k*V(out1)+(1-k)*V(out2)}
.noise V(Vmux) V1 dec 12 0.01 1e9
.step param k list 0 1
Let me know if it works!
    \$\begingroup\$ This is what Mike Engelhardt does but with voltage controlled switches. \$\endgroup\$
    – DavidG25
    May 9, 2018 at 0:22
-1
This tool lets you examine all the noise sources, simultaneously, and show final SNR/ENOB for a given Input VoltPP at a given FrequencyOfInterest (FOI). I've not activated the "gargoyles", the magnetic/electric/VDD/GND trash sources.
Here are thermal distortion (opamp shifts in input offset voltage, because of heating; and resistor value shifts that cause changes in Closed Loop Gain.) and the unified presentation of all the KT/Boltzmann/Johnson random noise.
Here is the 3 opamp signal chain, to amplify a 100uVpp signal to fit a 5vpp ADC. For low noise, the first opamp uses params (UGBW, Rnoise, Rout, DC_gain) of OPA211. The Gain Set resistors are also very low values.
    \$\begingroup\$ The question was about LT spice, thanks for playing. \$\endgroup\$
    – Voltage Spike
    Apr 22, 2017 at 7:28
  • \$\begingroup\$ They wanted to do noise analysis. \$\endgroup\$ Apr 22, 2017 at 12:24
  • \$\begingroup\$ I wanted to do a specific type of noise analysis in LT spice, if you would take the time to read the question and answer the question you would have known that \$\endgroup\$
    – Voltage Spike
    Apr 26, 2017 at 20:00
